Alternator Pulley - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Alternator Pulley (/showthread.php?tid=28776) |
Alternator Pulley - CJRODELL - 17-01-2015 Trying to take out the pulley from my nackered alternator to swap it out and put on an alternator from peugeot 405 but haven't got the proper tools to get the multispline bolt any tips on how to get it undone?? RE: Alternator Pulley - cully - 17-01-2015 umm BUY the correct tool! RE: Alternator Pulley - CJRODELL - 17-01-2015 I've got the multi bit but i can't undo it with out the pulley spinning! RE: Alternator Pulley - Toms306 - 17-01-2015 You need the other tool to counter hold it... RE: Alternator Pulley - CJRODELL - 17-01-2015 (17-01-2015, 04:30 PM)Toms306 Wrote: You need the other tool to counter hold it...what tool is it?? RE: Alternator Pulley - cully - 17-01-2015 18" stilsons RE: Alternator Pulley - Toms306 - 17-01-2015 Tbf I read it wrong, thought it was a clutch pulley, not sure if they're the same! If they are, you get a multispline outside with a hole through it so you can counterhold that while undoing the centre bolt. RE: Alternator Pulley - CJRODELL - 17-01-2015 (17-01-2015, 05:05 PM)Toms306 Wrote: Tbf I read it wrong, thought it was a clutch pulley, not sure if they're the same! Okay will give it ago! |
