EGR Blank
I've bought an EGR inlet blank from ebay and fitted it with homemade gaskets.
Am I done or do I need to disconnect the EGR solenoid?
Thanks,
Dave
That's it, that's all you have to do. Unplugging the solenoid may incur a fault code.
(29-12-2014, 05:29 PM)DeeTurbo Wrote: That's it, that's all you have to do. Unplugging the solenoid may incur a fault code.
Cheers!
I usually unplug it and then delete it from the ECU and then you get no fault, but leaving it as is will only bring a silent fault and no fault light on the dash so it doesn't matter what you do either way.
HDI Tuning Ltd
www.hdi-tuning.co.uk
  egr blank fgrc76 12 6,687 24-04-2015, 10:54 PM
Last Post: Iceman299
  manual boost controller and egr blank plate fitting, please help dirtyboost89 6 4,501 02-03-2015, 11:50 AM
Last Post: dirtyboost89
  EGR Push in type blank? pugdan95 5 4,022 09-01-2015, 07:21 PM
Last Post: doski
