Changing Rods
Changing Rods
What do I need when changing rods? New shells and bigend bolts? And where is best place to get them from? Looking to change the 16v rods into a new engine so making sure I know what to look for in advance
Thanks
Also had a VR headgasket fitted not long ago would it be ok to reuse this when heads removed
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
When I fitted hdi rods to my old engine, I just used same shells and bolts, just make sure there in good condition, my old bottom end is still going in fine to.
no need to replace bolts or shells if they're in good nick
headgasket on the other hand, yes would change this out
you need new rods too..
/Toseland
I do now there f*cked lol
Blaze 1.6 Dead
can get away with just using a new HG.
Reuse bolts, rod studs, rings, shells, oil, etc etc.
In a no expense spared build these should all be replaced though.
Well if you really didn't want to replace the headgasket you could take the crank out
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
