Changing Rods - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Changing Rods (/showthread.php?tid=26456) |
Changing Rods - HDIkyle - 03-09-2014 What do I need when changing rods? New shells and bigend bolts? And where is best place to get them from? Looking to change the 16v rods into a new engine so making sure I know what to look for in advance Thanks Also had a VR headgasket fitted not long ago would it be ok to reuse this when heads removed RE: Changing Rods - Chris_90 - 03-09-2014 When I fitted hdi rods to my old engine, I just used same shells and bolts, just make sure there in good condition, my old bottom end is still going in fine to. RE: Changing Rods - zx_volcane - 03-09-2014 no need to replace bolts or shells if they're in good nick headgasket on the other hand, yes would change this out RE: Changing Rods - toseland - 03-09-2014 you need new rods too.. RE: Changing Rods - HDIkyle - 06-09-2014 I do now there f*cked lol RE: Changing Rods - Dave - 12-09-2014 can get away with just using a new HG. Reuse bolts, rod studs, rings, shells, oil, etc etc. In a no expense spared build these should all be replaced though. RE: Changing Rods - andyyy - 13-09-2014 Well if you really didn't want to replace the headgasket you could take the crank out |
