Threads: 11
Car Model/Spec: 306 GTI-6 trackday toy
Given 2 thank(s) in 2 post(s)
I'm looking into replacing my 307sw 2.0 with something else, and the 407sw 2.2hdi Fap came up as a reasonable replacement, reasonably roomy and decent prices.
But I have zero experience in these engines, what should I be on the lookout for? Particulate filter, cleanable or is a replacement necessary?
Does anyone know how to check if the car is a face-lift ed model? Wikipedia said the 2.2hdi was introduced with the face-lift but I see a bunch of my07 cars for sale with that engine.. Very confusing!
Threads: 42
28
25-08-2014, 10:22 AM
(This post was last modified: 25-08-2014, 10:23 AM by welshpug.)
I would buy a d9 406 instead, same engine, much better shape to the boot, its a proper estate not an sw, the 407 tailgate opening is really poor for the cars size, or get a citroen c5 with the same engine.
if the dpf causes issue just get it removed and mapped out, you can also gain a decent 30-40 bhp on a standard engine.
in any case listen out for dmf noises, ticking injectors, boost leaks, excessive snoke and lack of power, nothing too difficult to fix but can add up in cost especially if you dont fix it yourself.
very similar in operation to the dw10ated4, but a longer stroke bigger bore taller engine.
Threads: 26
4
Car Model/Spec: Peugeot 406 Coupe 3.0 V6
Given 15 thank(s) in 13 post(s)
Top advice there from Welshpug
Threads: 11
406 is, unfortunately, out of the question due to tax rules on diesel cars made before 2005.
Besides, I have an 05 307, and i want something that is at least not older than my present ride [WHITE SMILING FACE]
Threads: 476
81
Car Model/Spec: 306 Rallye
my main worry with any new car would be the clutch/fly wheel. expensive to replace and i believe its not something you particularly want to be doing yourself.
Threads: 236
36
Car Model/Spec: '01 HDi DTurbo
Focus estate? Not a 2.2 but the 136 2.0 TDCi/HDi engine is pretty good.
![[Image: Sig500x130.png]](http://i430.photobucket.com/albums/qq25/chris_rx71/Sig500x130.png)
Threads: 42
28
I'd go Volvo before a focus, same platform same engines but better put together and didn't get DPF till later on.
Threads: 91
83
^^ Just FYI that's not entirely true, seen P1 platform cars with the BTED4 with a DPF on an 06 plate - DPFs on them came mid way through Euro4. I've seen Focusses with the 2.0 on a 57 plate with no DPF.
The 1.6s had DPFs very early on, but the 2.0s not so much in my experience.
Threads: 386
87
25-08-2014, 11:44 AM
(This post was last modified: 25-08-2014, 11:48 AM by Toms306.)
Nothing wrong with a DMF, its no different to change than an SMF, just a bit more expensive. Its also easier to drop the gearboxes on newer cars as everything isn't rusty and seized lol. And they'll easily last 120k+ under normal conditions, same time as the clutch starts the fail anyway.
DPF is the bigger worry, especially PSA ones with the Eolys fluid which are only expected to last around 75k miles before being blocked by regen ash which cant be 'cleaned'. Needs replacing then as it's now illegal to just remove them (yes illegal, not just an MOT fail). May be different in Sweden but I'd imagine they're much hotter on emmisions stuff out there tbh.
On the 2.2 it's also a VNT turbo, which come with their own 'sticking' problems if its been driven slowly by old people previously lol.
Also, 2009 is when the Euro 5 regs came out, which meant that almost all diesels in Europe then needed a DPF, there are quite a few smaller cars without one up to then which has surprised me a bit. However the Euro regs wont apply to Sweden so it may differ whether or not the cars there have a DPF with the same engines if that makes sense.
Threads: 91
83
For the record, my V50 has done 112k of town driving and my driving - DMF isn't chattery nor is the clutch slipping... So meh - anything past 100k for a clutch I consider a bonus.
Threads: 42
28
I didn't think it was a VNT on the 2.2 407 but a twin turbo thing as its the 173 engine.
The 406 was just a bog standard solenoid wastegate as that only got the 136 bhp engine.
either way, if you're after something specifically to use as an estate to replace a 307, 407 wouldn't be my first choice, C5 would be though.
or a petrol BMW, as the diesels suck wotsits.
Threads: 386
87
Ah, my bad, you are right, they're not VNT. Been looking at some many cars and engines lately I'm getting them crossed lol.
Threads: 91
83
The DW12ATED4 as in the 406/807/406 coupe etc is a GT1549P - it's a Variable Geometry turbo... Not Variable Nozzle - it's the same system as they use in larger frame VGT Holset turbochargers.
Essentially slides a set of Nozzles into the flow of the turbo to restrict the flow and increase gas velocity:
Looks like this inside:
Notice nozzles aren't adjustable in their attitude, only adjustable moving it further outward to stop the gas being accelerated into the turbine wheel.
Threads: 42
28
ahhh, wondered what was going on with the weird location of the solenoid.
Threads: 386
87
Ah that's interesting, had heard of VGT but didn't know the difference.
Threads: 11
So the fact that every review I've read, has stated that it's a twin turbo setup, is a lie? Kinda suspected it but it's nice to get it confirmed :-)
Threads: 91
83
The 2.2 170 possibly is a twin turbo setup yes - though I think the 2.2 birturbo only came on late cars.
They also put the 2.2 in LR Freelanders/Range Rover Evoques but had a single turbo and 170hp... So could be either.
Threads: 42
28
there's only one 2.2 hdi listed on servicebox for the 407.
Threads: 91
83
Sure, there's possibly only one....
I think I meant to say, the 2.2 engine only came in very late cars...
I think it's rare since the 2.0 16v then went to 168hp which then made the 170 2.2 defunct.
Threads: 11
Did some research, seems to be the dw12bted4 or 4HT engine that's fitted to my price range of cars.
Threads: 236
36
(25-08-2014, 12:03 PM)welshpug Wrote: or a petrol BMW, as the diesels suck wotsits.
eek, why do you say that? (potentially looking at BMW 320d...)
Threads: 42
28
Depends which variant, but theres lots of info about on them
Threads: 91
83
Lol yeah most BMW Diesels before about 2007 have real problems, swirl flaps, failing injectors, failing (read: rattly as f*ck) chain tensioners, turbo issues all sorts like that - wouldn't touch unless you don't mind horrifying bills.
Threads: 236
36
I knew about the swirl flaps and the dodgy oil pickup but it was my understanding that anything 53 plate onwards was safe from these issues?
Injectors appear no worse than any other diesel of that age? With the exception that you can (apparently) replace only the faulty injector rather than needing a whole new set like certain Fords...
Please divulge!
Threads: 93
8
Car Model/Spec: Stock HDi Meridian & Mk2 MX-5
Given 1 thank(s) in 1 post(s)
Dad's E46 330d shat the turbo and cost a grand to put right. I lol'd. He hasn't had any swirl flap issues though, despite being on about 150k miles and having a remap.
![[Image: sigcopy-1.jpg]](http://i570.photobucket.com/albums/ss147/KEZZIEBOY/Diablo%20HDi/sigcopy-1.jpg)
Threads: 34
8
Given 8 thank(s) in 8 post(s)
The *35s dont tend to suffer turbo problems.. maybe because there is 2? Lol neighbours 320d has had turbo and injectors done, hes had since new in 2003 and its done nearly 180k so isnt that bad tbh
Threads: 591
54
Any "new" diesel is going to need turbo and injector rebuilds or replacements or work on them at some point. Its part and parcel of life and wear/tear.
As regards DMF though...it may not be all that more expensive to buy one and replace than a SMF but how often does a SMF fail????? VERY RARE. DmF....pretty damn common.
Threads: 42
28
you don't want a SMF on big power diesels, they will lunch the transmission a fair bit quicker than they do already.
DMF's dont fail anywhere near as much as the first generation did 15 years ago.
Threads: 91
83
Yeah definitely...
DMFs are a good thing, just were executed badly to begin with! Without them you'll lunch transmissions, clutch springs etc.
These days they're pretty much fine, it was stuff like the original 110hp HDis, Ford Camchain TDCis and 1.9 PD TDis that gave DMFs a bad name!
Threads: 236
36
Well, f*ck. Here I was checking Autotrader every bloody night and you lot have gone and ruined my desire for a BMW e46.
Damn you.
