Switched Live
Hi Guys. Im wiring up my windeband which requires a switched live. Any idea where to get one around the dash area? Easiest is the head unit remote wire but id rather not tap into that as im sure its not designed to be used that way.
Anything around the dash dimming, window disable, headlight adjustment, airbag bypass area?
Cheers
Sam
How about the ignition barrel?
fuse board by your knee atleast half of it only comes on with the ign
yep I think Ill have to check out the fuse box. Bound to be something there but i was going to avoid it if at all possible!
Either right off the barrel or the fusebox tbh, hundreds of big wires there...
[Image: sigi-2.png]
Fag lighter? With the fuse in the right place thats ign live.
(22-08-2014, 04:10 PM)Slam Wagon Wrote: Fag lighter? With the fuse in the right place thats ign live.
Yeh I did find that out but I have my fuse in the other position. It needs to be permanent live so that I can charge the gopro and phone when im not in the car.
  Central locking + stereo switched live Chris_90 6 5,186 14-07-2013, 04:32 PM
Last Post: RPMotorsport
