12-08-2014, 08:05 AM
Just wondering what size socket(s) will be needed to convert from lucas to bosch?
Cheers,
Phil
Cheers,
Phil
No smoke, No poke!
injector socket
Cheers, Phil
No smoke, No poke!
12-08-2014, 09:20 AM
Will just a normal deep socket do the job? Or do i need an actaul socket for injectors?
No smoke, No poke!
12-08-2014, 01:06 PM
Heard the halfords ones arent deep enough tho?
12-08-2014, 01:22 PM
Ahh balls typical i have halfords ones haha any particular make then?
No smoke, No poke!
12-08-2014, 01:47 PM
I used a halfords one and it was fine.
Bye Bye D-Turbo
Phase 1 GTi-6 now has a new owner Rolling in the: Phase 3 HDI Wagon The current estate project: http://306oc.co.uk/forum/thread-22237.html
12-08-2014, 02:02 PM
It depends - a big 27mm generally will fit, but some have casting marks which won't clear the leak off nipples.
Halfords ones it depends who they're using to make the sockets these days, they used to fit, but I've a suspicion I've heard someone say they bought one and it didn't fit - so essentially - it's a stab in the dark. If it doesn't fit, you'll just have to take it back!
12-08-2014, 03:37 PM
27mm spanner
12-08-2014, 05:33 PM
I use a 27mm halfords socket. I needed to hit the socket on the lucas injectors and it f*cked the thread on the injector line bosch injectors it's fine though
12-08-2014, 06:26 PM
27mm injector socket
12-08-2014, 06:29 PM
draper do specific 27mm injector sockets.
12-08-2014, 06:34 PM
I bought a 27mm deep socket and an injector socket when I took some off. Injector one worked fine and returned the unused one.
12-08-2014, 07:14 PM
I cut a socket in half and welded a bit of handrail tube between it
12-08-2014, 07:31 PM
I had a Draper one too, was cheap and does the job.
12-08-2014, 08:08 PM
13-08-2014, 02:43 AM
(12-08-2014, 06:29 PM)welshpug Wrote: draper do specific 27mm injector sockets. as do laser tools, local motorfactors, wont be the cheapest in the world but it works a treat! Given the choice between Niall and the sheep. I would choose the sheep!
/Toseland
13-08-2014, 07:19 AM
(12-08-2014, 06:29 PM)welshpug Wrote: draper do specific 27mm injector sockets. This. You won't go wrong. Don't do halfrauds.
