Threads: 210
1
Car Model/Spec: Ph1 White Gti6/306 DTurbo
Given 7 thank(s) in 7 post(s)
Thought I'd put up my plans for the DTurbo and see what you think. And what you think can be added to the list
Exterior:
Wheel refurb
Black mask or possibly white mask
Ph3 indicators
Possibly re-spray the strip under the boot lid
Rallye blanks
Interior:
White ph3 dial needles
Redo headliner in black
Black cabriolet sun visors
DTurbo floor matts including boot carpet
White clock faces
White clock LED kit
Mechanical:
Straight through system
Bosch pump
Tune the Bosch pump
Gti6 beam
Gti6 brakes
Possibly coilovers
New Valeo clutch
Give engine a clean up
Possibly new turbo once tuned (looking for around 170 BHP)
Maybe FMIC
That's just my rough list I would really appreciate it if you guys can tell me what you would do so I can get an idea of what's possible and what is usually done on these cars
Threads: 58
Car Model/Spec: v70r
Given 1 thank(s) in 1 post(s)
Threads: 210
1
(07-08-2014, 10:53 AM)ADV_93 Wrote: TD04L/GT20.
What would you say is the better turbo?
Threads: 14
7
Given 5 thank(s) in 5 post(s)
Shove a bosch pump on it and run a ton of veg.
Spend the rest on coke and hookers.
Threads: 19
1
Car Model/Spec: phase 1 sedan SLDT
Hopefully the GT20 is the better turbo as that's what I've bought based on reading through the forum. More efficient and spools faster. Would it not be worth changing to the HDi rods at that sort of power level just to reduce the risk a bit?
Threads: 371
29
Car Model/Spec: ford fiesta
(07-08-2014, 11:12 AM)r3k1355 Wrote: Shove a bosch pump on it and run a ton of veg.
THIS. Theres a thread about a drug smuggling 306 as well.
Threads: 210
1
07-08-2014, 11:41 AM
(This post was last modified: 07-08-2014, 11:42 AM by Nathan1305.)
(07-08-2014, 11:35 AM)simonh Wrote: Hopefully the GT20 is the better turbo as that's what I've bought based on reading through the forum. More efficient and spools faster. Would it not be worth changing to the HDi rods at that sort of power level just to reduce the risk a bit?
170bhp is something I'll aim for in the future at the moment I'm looking for around 130bhp which I'm hoping I can do from just a Bosch pump and free flowing exhaust
(07-08-2014, 11:36 AM)bashbarnard Wrote: (07-08-2014, 11:12 AM)r3k1355 Wrote: Shove a bosch pump on it and run a ton of veg.
Haha ill get reading
Threads: 48
5
Car Model/Spec: Peugeot 306 S16 Cossack
Given 2 thank(s) in 2 post(s)
130 is easily achievable from a stage 1 tune. What turbo has it got?
However its important to remember that your cooling system is in good working order.
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Threads: 19
12
Before chasing more power, give the engine a service (unless you have accurate service history)
Oil, Air, Fuel Filters, Cambelt and Water pump. As Anton says make sure the cooling system is working well as heat is what kills the XUD.
Threads: 210
1
07-08-2014, 12:03 PM
(This post was last modified: 07-08-2014, 12:18 PM by Nathan1305.)
(07-08-2014, 11:42 AM)Anton Wrote: 130 is easily achievable from a stage 1 tune. What turbo has it got?
Not sure what turbo it's just a standard one but don't know how to tell what one it is. So if I got a Bosch pump is there people on the forum that can tune, gov mod and LDA grind it for me? So with cooling will a FMIC help this?
(07-08-2014, 11:58 AM)mr_fish Wrote: Before chasing more power, give the engine a service (unless you have accurate service history)
Yeah I'm planning on getting the parts I need ready then doing a full service so it's all in top condition for the power increase
Threads: 41
3
Car Model/Spec: 306xrdt ph1
Given 4 thank(s) in 4 post(s)
(07-08-2014, 11:36 AM)bashbarnard Wrote: (07-08-2014, 11:12 AM)r3k1355 Wrote: Spend the rest on coke and hookers. THIS. Theres a thread about a drug smuggling 306 as well.
You mean store it inside the chassis ?
With the handy hole on every 306 just under the rear seat belt pointing point ?
Threads: 58
(07-08-2014, 11:07 AM)Nathan1305 Wrote: (07-08-2014, 10:53 AM)ADV_93 Wrote: TD04L/GT20.
It depends on how you drive tbh. The TD04L is a late spooler but goes on far up the rev range (but i'm a mid-top sort of driver), but the GT20 is a faster spooler
Threads: 3
Is it much work fitting a gt20 to a xud ?
Threads: 0
45
Nathan, don't get too carried away as you may struggle insuring all those engine modifications in your first year..
Threads: 210
1
(07-08-2014, 02:40 PM)ADV_93 Wrote: (07-08-2014, 11:07 AM)Nathan1305 Wrote: (07-08-2014, 10:53 AM)ADV_93 Wrote: TD04L/GT20.
Gt20 sounds more like what I'm after
(07-08-2014, 03:01 PM)JJ0063 Wrote: Nathan, don't get too carried away as you may struggle insuring all those engine modifications in your first year..
Yeah I'm just getting an idea of what I want to do  thinking of doing it all after my first year, might as well get an idea. Just going to do a few mods now, mainly concentrating on servicing and making it a clean example
Threads: 58
(07-08-2014, 07:43 PM)Nathan1305 Wrote: (07-08-2014, 02:40 PM)ADV_93 Wrote: (07-08-2014, 11:07 AM)Nathan1305 Wrote: What would you say is the better turbo?
A standard d turbo is more than adequate for today's city driving and economy
