Is this illegal?
Is this illegal?
#61
[Image: auto-part-ball-joint-for-peugeot-306-good-quality.jpg]
Right that is a 306 balljoint. The bit with the 3 holes sits inside the end of the wishbone. You want to measure from one of them bolt holes to the ball joint pin its self. I bet you will find that the one on the side your having troubles with is shorter than the other side. If so, replace the ball joint (only about £15 from ECP) with one for a PAS car.
(21-06-2014, 12:58 PM)Niall Wrote: [Image: auto-part-ball-joint-for-peugeot-306-good-quality.jpg]
Awesome thanks Niall Smile so I wanna measure from the centre of the hole to the centre of the ball joint pin like this?
[attachment=17003]
yeah can do. you will have to remove the ball joint from the hub to dp that so you could just measure both from one of the bolts to a point on the back of the hub
(21-06-2014, 01:41 PM)Niall Wrote: yeah can do. you will have to remove the ball joint from the hub to dp that so you could just measure both from one of the bolts to a point on the back of the hub
Yeah that way will be easier so measure from the bolt to the hub
