307 6 speed gearbox
307 6 speed gearbox
Where is the level plug? Haynes had got a diagram but it makes no sense to me,
what oil dose it take? 75w90?
Thought they all took the same 75/80 oil and 2 litres of it? That's what the guy at Pug told me back before I knew what I needed lol.
There is two types of this box listed, one takes 1.6 and the other is like 2.3 i think, there is some difference in the cooling fins on the case,
i was planning to keep filling it via the reverse sensor untill the level plug but i cant find it
Can you fit the 307 6 speed gear box to the 306 hdi?
(11-06-2014, 10:10 PM)Daniel306 Wrote: There is two types of this box listed, one takes 1.6 and the other is like 2.3 i think, there is some difference in the cooling fins on the case,
Oh OK, my bad then!
Level plug will most likely be on the end nearest the wheel, and just have a slightly bigger bolt head than the others in the same area. That's how it is on the 306 HDi box.
(11-06-2014, 10:10 PM)SRowell Wrote: Can you fit the 307 6 speed gear box to the 306 hdi?
Not easily, theres a thread on this from a couple of days ago.
Thats what i thought but its just a steel end cap on it, book says its in by the drive shalft but thats where i got lost
Hmm, have you tried a 307 Forum? It's obviously very different to the 306 equivalent lol.
Though it looks like there is no level plug on the ML6 'box from a quick search, just fill to the correct amount depending on whether you have fins or flanges lol.
  6 Speed Gearbox Alan_M 30 12,789 22-10-2014, 11:46 PM
Last Post: akuma406
  dw10 with 6 speed gearbox dashmader 23 8,336 29-07-2014, 11:16 AM
Last Post: welshpug
