ABS Ring Replacement
Hello,
Just wondering if I'd be able to change an ABS ring at home?
Not sure how hot it needs to be to expand? Would a heat gun get hot enough?
Or would it have to be a garage job with a blowtorch?
Cheers
Tom
Try a heat gun, failing that, get yourself a handheld blowtorch
Would rather not have to buy one as the ring only costs £2 lol. Will try the heatgun though, see how it goes.
Cut old one off, put new one in oven for 10 mins on hot hot, wear oven glove, smash it on.
Simple as that lol
What sort of temp would you put the oven at?
Old one is split btw, so should come off without cutting hopefully!
put it on max, shelf at the very top, that should do it
Project: Formula Peugeot
I replaced my front offside ABS ring last year - just tapped it on carefully with a hammer, no heat involved. Still fine 10k later! Was £2 delivered from eBay I think.
£1.40 posted for the one I think I need...
Should be tighter than just tapping on surely lol? But nice and easy if that is the case!
Did my brothers too without heat, easy.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
It's definitely not going to come off was a nice tight fit once tapped on, it's fairly soft metal so probably just stretches slightly
A bit too soft clearly if they're that prone to splitting! Dodgy
Have ordered one now anyway, will see how it goes. Smile
Well typically I ordered the wrong size lol. Got the right size yesterday and fitted fairly easily. Didn't use any heat, did use a lump hammer though lol. However it was over 20c in the sun, so might be a different story in the depths of winter.
  ABS sensor ring issue jim1500 3 4,077 22-06-2018, 01:08 PM
Last Post: jim1500
  Swapping reluctor ring on drums Petebob 6 3,813 28-07-2014, 08:35 PM
Last Post: Petebob
  What abs ring do I need stu9 0 1,987 08-08-2013, 08:46 AM
Last Post: stu9
