ABS sensor ring issue
Hi, I'm posting onĀ behalf of a friend with an immaculate 2000 306 auto 1.6. The ABS ring which is plastic has split and causing vibration on the pedal. The only way he has been able to get a new one was by buying a complete CV joint, but this has a metal ring (correct amount of windows on it).
Just wondering if anyone knows if this will work ok as it's a fair bit of to fit the whole joint to find out that it doesn't work.
Alternatively would anyone know if he could get a replacement plastic ring anywhere??
Smile Many thanks in advance
Thy all came out if factory metal. Plastic was cheap nasty aftermarket ones. You may also want to replace the sensor if it's rubbed in it.
try J&R driveshafts in Birmingham..i remember seeing that they sell abs rings ??? worth a try anyway..
Great, cheers for the help Smile
  Swapping reluctor ring on drums Petebob 6 3,813 28-07-2014, 08:35 PM
Last Post: Petebob
  ABS Ring Replacement Toms306 11 5,986 08-06-2014, 02:16 PM
Last Post: Toms306
  What abs ring do I need stu9 0 1,987 08-08-2013, 08:46 AM
Last Post: stu9
