30-05-2014, 12:14 PM
(30-05-2014, 09:47 AM)cpikey316_ Wrote: Nothing like smoke or dodgy idle? The fact that they could die 10 minutes into ownership is worrying
But then they may last years!
The TDCi's tend to be pretty smoky anyway, same as the Jag X types with the Mondeo engine...not sure if its something to do with the EGRs sticking or DPF getting blocked maybe? These have both DMF and DPF unfortunately. If you want to avoid a DPF, go for a CDTi or a PD engine at the same age.
As for failing in 10 minutes or 10 years, that's the same with any car.... When you bought the HDi the crank pulley could've fallen apart and snapped the belts on your way home. This is just the luck of the draw with used cars unfortunately.
