cyclones on xsi wont fit ?
hi ive got a spare cyclone alloy but the bolts wont screw in correctly do i need a spacer or am i missing something.
cheers
have you got the right bolts?
They should fit fine, whats stopping them from fitting?
If you have lasers atm though and using those bolts, the bolts will stick out too far.....
youre using flat bolts yeh? Not the ones with the angled part?
these...
[Image: Peugeot-Citroen%20NEW%20type%20bolt%20M1...0image.jpg]
not these...
[Image: wheel-bolts-14mm-taper-dome-2.jpg]
seems a bit of an odd situation? i had no problems putting a cyclone on my mrs xsi with laser bolts slotted straight on like i was putting the on any other 306?
Have you cross threaded the bolt fitting it thus destroying the thread in the hub?
[Image: c6769879.jpg] TEAM TRACK CAR + An E60 530d M-Sport for the daily
you may need bolts that dont have that shoulder
More like this
[Image: DSC00907.jpg]
than thease
yep, as Daniel said - you need to make sure your bolts are not tapered.
simple google search will find your answer...
http://reviews.mtbr.com/wp-content/uplo ... d-bolt.jpg
the bolts were to big luckly i checked cos if i had a flat i would be screwed. just bought some bolts of ebay also bidding for a full set of cyclones as they are smart.
thanks anyway Smile
