cyclones on xsi wont fit ? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: cyclones on xsi wont fit ? (/showthread.php?tid=1976) |
cyclones on xsi wont fit ? - skyline2k - 04-03-2012 hi ive got a spare cyclone alloy but the bolts wont screw in correctly do i need a spacer or am i missing something. cheers Re: cyclones on xsi wont fit ? - kingy - 04-03-2012 have you got the right bolts? Re: cyclones on xsi wont fit ? - Toms306 - 04-03-2012 They should fit fine, whats stopping them from fitting? If you have lasers atm though and using those bolts, the bolts will stick out too far..... Re: cyclones on xsi wont fit ? - Eeyore - 04-03-2012 youre using flat bolts yeh? Not the ones with the angled part? these... ![]() not these... ![]() Re: cyclones on xsi wont fit ? - puglove - 04-03-2012 seems a bit of an odd situation? i had no problems putting a cyclone on my mrs xsi with laser bolts slotted straight on like i was putting the on any other 306? Re: cyclones on xsi wont fit ? - Ian - 04-03-2012 Have you cross threaded the bolt fitting it thus destroying the thread in the hub? Re: cyclones on xsi wont fit ? - Daniel306 - 04-03-2012 you may need bolts that dont have that shoulder Re: cyclones on xsi wont fit ? - Daniel306 - 04-03-2012 More like this ![]() than thease ![]() Re: cyclones on xsi wont fit ? - ginge191 - 04-03-2012 yep, as Daniel said - you need to make sure your bolts are not tapered. simple google search will find your answer... http://reviews.mtbr.com/wp-content/uplo ... d-bolt.jpg Re: cyclones on xsi wont fit ? - skyline2k - 05-03-2012 the bolts were to big luckly i checked cos if i had a flat i would be screwed. just bought some bolts of ebay also bidding for a full set of cyclones as they are smart. thanks anyway ![]() |
