ecu change
ecu change
Looking to change my ecu to a stage 1 ecu,
What do i need to get so it works?
Ecu,thing under ignition anything else?
[Image: 13073041_458228241037318_1249062425_o_zpsoh6qf7gu.jpg]
why not just get yours remapped?
(10-05-2014, 06:03 PM)PE02KHG Wrote: why not just get yours remapped?
I dont want to take the chance of bricking the ecu,
And would find it easier changing ecu
The chances are pretty damn low if you take to the mapper.
(10-05-2014, 06:30 PM)PE02KHG Wrote: The chances are pretty damn low if you take to the mapper.
Im the wrong side the water to go to the mappers on here, and it will cost more buying the cable and the map compared to a ecu,
Fair enough then. I think you just need the ecu and bsi. Not 100% sure though.
Buy ECU with same S/W H/W numbers as original, send to Pro Steve for de-immob and re map, job jobbed. Smile
Think he means hes going to buy a pre-mapped ecu
I would just upload the map yourself using the correct cable, the chances of bricking the ECU are slim if you follow the proper procedure.
I must of uploaded 50 odd maps with no probs up to now... Smile
but again he stated that its cheaper for him to aqquire a st1 ecu than the map itself along with the cable supposedly Wink
Just keeping you on your toes haha
the things you need are ecu, chip in the key ,bsi.
(11-05-2014, 09:53 PM)mcglynn Wrote: but again he stated that its cheaper for him to aqquire a st1 ecu than the map itself along with the cable supposedly Wink
You not do it Eoghan, make a road trip outta it lol Tongue
wheres he from? I can upload like but wony be travelling lol
