ecu change - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: ecu change (/showthread.php?tid=23956) |
ecu change - tysonbully2k12 - 10-05-2014 Looking to change my ecu to a stage 1 ecu, What do i need to get so it works? Ecu,thing under ignition anything else? RE: ecu change - Slam Wagon - 10-05-2014 why not just get yours remapped? RE: ecu change - tysonbully2k12 - 10-05-2014 (10-05-2014, 06:03 PM)PE02KHG Wrote: why not just get yours remapped? I dont want to take the chance of bricking the ecu, And would find it easier changing ecu RE: ecu change - Slam Wagon - 10-05-2014 The chances are pretty damn low if you take to the mapper. RE: ecu change - tysonbully2k12 - 10-05-2014 (10-05-2014, 06:30 PM)PE02KHG Wrote: The chances are pretty damn low if you take to the mapper. Im the wrong side the water to go to the mappers on here, and it will cost more buying the cable and the map compared to a ecu, RE: ecu change - Slam Wagon - 10-05-2014 Fair enough then. I think you just need the ecu and bsi. Not 100% sure though. RE: ecu change - Uberderv - 10-05-2014 Buy ECU with same S/W H/W numbers as original, send to Pro Steve for de-immob and re map, job jobbed.
RE: ecu change - mcglynn - 11-05-2014 Think he means hes going to buy a pre-mapped ecu RE: ecu change - Uberderv - 11-05-2014 I would just upload the map yourself using the correct cable, the chances of bricking the ECU are slim if you follow the proper procedure. I must of uploaded 50 odd maps with no probs up to now...
RE: ecu change - mcglynn - 11-05-2014 but again he stated that its cheaper for him to aqquire a st1 ecu than the map itself along with the cable supposedly ![]() Just keeping you on your toes haha RE: ecu change - madmadmax - 12-05-2014 the things you need are ecu, chip in the key ,bsi. RE: ecu change - E_KEL95 - 12-05-2014 (11-05-2014, 09:53 PM)mcglynn Wrote: but again he stated that its cheaper for him to aqquire a st1 ecu than the map itself along with the cable supposedly You not do it Eoghan, make a road trip outta it lol
RE: ecu change - mcglynn - 12-05-2014 wheres he from? I can upload like but wony be travelling lol |
