Threads: 13
Car Model/Spec: 306 1.9 dturbo s
26-04-2014, 12:25 PM
(This post was last modified: 26-04-2014, 12:26 PM by dadaddy35.)
Hi all I know its not a 306 but its a 2.0 hdi engine. The wife's 206 sw has been making a strange noise lately. when you are slowing down there is like a whirring noise which disappears when you depress the clutch pedal.
It doesn't happen when driving only when slowing down and at lower revs.
Clutch release bearing possibly.
Threads: 190
Car Model/Spec: HDI
I bet its just the turbo whine you get when you let off the throttle and keep it in gear.
Threads: 20
Car Model/Spec: 306 hdi estate
Given 3 thank(s) in 3 post(s)
Mine does this as well, I was only saying about this to my other half today, I haven't a clue what it is though
Threads: 28
Car Model/Spec: Phase 4 Silver HDi Estate
when was the last time the gearbox oil was changed? new oil is first thing i'd do with a whine in gear
Threads: 28
will always get a little transmission noise but new oil will hopefully get it to minimal levels
Threads: 5
Have recently had this exact same problem! I found it hard to diagnose as stationary it would be silent! Essentially meaning the car had to be travelling to make the noise! After some trial and error I found the idlers were noisy also the auxiliary belt had become fairly perished! It's had life left in it but had seemed to start whipping around on overrun causing the idler to run a little dry etc! Giving me the horrible noise! Have replaced the belt now found the power steering pump is giving a similar noise when on full lock!
