23-04-2014, 03:23 PM
306 dturbo kkk 003
23-04-2014, 03:52 PM
(23-04-2014, 03:23 PM)mr_fish Wrote:(23-04-2014, 03:20 PM)silverzx Wrote: Love you Mark. Haha, good old bromance never hurt anybody. ![]() K03 to K14, your best off buying a K14 on a manifold with the oil line then it's a straight swap, the same could be said for T2, if you buy one on a manifold with the line as well it's a straight swap. These tend to go for around £40~60 on the forum as a rough guide. I think you'd be pleasantly surprised how easy it is to knock up a set of plates for common turbos like T25/TD04's.
23-04-2014, 03:56 PM
Cool ok il look for a k14 and manifold and oil lines i cant seem to post in wanted form
Yeah td04 is the way to go. Hence why I'm selling the k14
Or find a t2 manifold which will fit a k14 and come up more often.
23-04-2014, 05:26 PM
Much u selling k14 for ?
23-04-2014, 05:32 PM
40 quid posted? Can't have it for a week or so till I ft my td04
23-04-2014, 05:39 PM
Cool sounds good does it have manafold and fuel lines ?
23-04-2014, 05:44 PM
No manifold but oil lines you won't find one with manifold for less than 70 ish
23-04-2014, 05:45 PM
Ah ok il take that is that all il need ?
23-04-2014, 05:58 PM
Exhaust might need a bit of mod but yeah essentially.
25-04-2014, 12:18 AM
See you're based in Larne....
If it's big power you want, there's a scrappy in Camlough with a fair few 306's and 406's. There's a transit banana engine with pump. There's also a pair of E320's side by side with both their turbos still on them. For bolt on one of the 406's is a 97 so should have the T2/K14 (I got nothing off it..... Yet) Bring the 2 manifolds and all pipework. Get new o rings for the oil feed or oil will piss everywhere with the old hard seals. Get a 306 bosh pump with the transit pump and hybrid the 2 of them. There's a few guides on how to build them. 406 is semi ecu and doesn't work well without the ecu Avoid the 406/Xantia fmic as they are wank for heatsoak. Get something like a Vivaro fmic |
