Coil Spring Tubing
Coil Spring Tubing
Where can I get the rubber tubing that sits over the top and bottom coils of front springs??
I have some used Eibachs to go on that don't have any.
thanks Nick
Current - 306 ph1 xrdt - 323 estoril. History - Legacy Outback - Impreza Wagon - BMW 530 - Golf GTI mk2 - Escort TD - Audi 80 coupe - Astra GTE - Escort XR3
Project : http://306oc.co.uk/forum/thread-23625.html
Not sure, but it's not really necessary, I've only ever seen it on eibachs tbh!
It's not a necessity and defiantly not there for safety reasoning but if you want to have some one there I think it's called spring insulator. Also if you can't find any maybe slide some heat shrink on there?
Or this stuff?
http://www.completeautomobilist.com/prod...denso-tape
its to stop the paint scratching off the spring, allowing rust to lift paint off and let rust take hold---use some heatshrink as suggested.
Thanks All. Didnt put anyhting on in the end and no diiference to feel/drive. Next time they are appart i'll Kurust and paint if needed before heatshrink.
Cheers Nick
