Coil Spring Tubing - Printable Version
+--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19)
+--- Thread: Coil Spring Tubing (/showthread.php?tid=23379)
Coil Spring Tubing - nick000 - 19-04-2014
Where can I get the rubber tubing that sits over the top and bottom coils of front springs??
I have some used Eibachs to go on that don't have any.
thanks Nick
RE: Coil Spring Tubing - Toms306 - 19-04-2014
Not sure, but it's not really necessary, I've only ever seen it on eibachs tbh!
RE: Coil Spring Tubing - bashbarnard - 20-04-2014
It's not a necessity and defiantly not there for safety reasoning but if you want to have some one there I think it's called spring insulator. Also if you can't find any maybe slide some heat shrink on there?
Or this stuff?
http://www.completeautomobilist.com/products/ca970-drevo-denso-tape
RE: Coil Spring Tubing - daddyfixit - 20-04-2014
its to stop the paint scratching off the spring, allowing rust to lift paint off and let rust take hold---use some heatshrink as suggested.
RE: Coil Spring Tubing - nick000 - 01-05-2014
Thanks All. Didnt put anyhting on in the end and no diiference to feel/drive. Next time they are appart i'll Kurust and paint if needed before heatshrink.
Cheers Nick
