Threads: 21
As per title really, aint driven the car for a week as I was away. The last two times I turned the ignition on, all of the clocks do a full sweep. Including temp and fuel and the oil pressure. Anybody know what this means?
Threads: 162
21
Isn't that an earth fault?
Usually a low battery or crap terminal in my experience.
Yep that usually indicates a lower than normal cranking voltage. 9 times out of 10, thats a battery on its way out but can also be an earth fault of bad wiring.
Threads: 183
20
Given 8 thank(s) in 8 post(s)
I also had this on mine but never got round to sorting it.
Threads: 206
Car Model/Spec: 3dr dt-s
quite common; its called capacitance------disconnect both battery leads and touch them together, refit them to the battery and that's it.
