What does it mean when your clocks do a full sweep? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: What does it mean when your clocks do a full sweep? (/showthread.php?tid=23360) |
What does it mean when your clocks do a full sweep? - HD-Aye! - 18-04-2014 As per title really, aint driven the car for a week as I was away. The last two times I turned the ignition on, all of the clocks do a full sweep. Including temp and fuel and the oil pressure. Anybody know what this means? RE: What does it mean when your clocks do a full sweep? - DeeTurbo - 18-04-2014 Isn't that an earth fault? RE: What does it mean when your clocks do a full sweep? - Matt - 18-04-2014 Or a battery issue RE: What does it mean when your clocks do a full sweep? - Toms306 - 18-04-2014 Usually a low battery or crap terminal in my experience. RE: What does it mean when your clocks do a full sweep? - HD-Aye! - 19-04-2014 Sounds about right, I had been away for a week so battery was prob low. Its not doin it anymore ![]() RE: What does it mean when your clocks do a full sweep? - Niall - 19-04-2014 Yep that usually indicates a lower than normal cranking voltage. 9 times out of 10, thats a battery on its way out but can also be an earth fault of bad wiring. Re: What does it mean when your clocks do a full sweep? - kentiiboii - 20-04-2014 I also had this on mine but never got round to sorting it. RE: What does it mean when your clocks do a full sweep? - daddyfixit - 20-04-2014 quite common; its called capacitance------disconnect both battery leads and touch them together, refit them to the battery and that's it. |
