16-04-2014, 12:15 PM
Does anyone know off the top of there head the diameter of the c5 bottom turbo pipe and the 406 inlet elbow
406 elbow diameter
16-04-2014, 12:55 PM
51mm if I remember correctly
Bye Bye D-Turbo
Phase 1 GTi-6 now has a new owner Rolling in the: Phase 3 HDI Wagon The current estate project: http://306oc.co.uk/forum/thread-22237.html
What 406 inlet elbow are you using, one with the air dozer or without? I am not sure if they are the same or not.
And the c5 bottom pipe which end do you want to know, both ?
16-04-2014, 02:36 PM
Is the air doser the erg???
16-04-2014, 02:49 PM
16-04-2014, 02:57 PM
Ill try and get one without it and Im asking about the intercooler end of the c5 bottom pipe
16-04-2014, 05:25 PM
Thats a bit poo as the outlets on my intercooler are 51mm
16-04-2014, 06:12 PM
16-04-2014, 08:16 PM
Thats pretty standard. 51 is 2" and then 57 is 2.5". 51mm will be easier to fit past the rad and then somewhere in the piping you can step it up to 57 ready for the inlet.
16-04-2014, 08:29 PM
I think ill use 2 inch pipe all the way to the inlet then use a reducer to fit it not sure how I can do the bottom pipe yet
| Diameter of the elbow for turbo connection | mattbarker32 | 5 | 3,262 |
18-09-2016, 08:14 PM Last Post: toseland |
| Lower air box pipe diameter? | JTaylor2005 | 2 | 2,250 |
26-01-2016, 09:22 PM Last Post: DeeTurbo |
| Air filter inlet diameter | aaron_one | 5 | 3,228 |
02-11-2015, 02:06 PM Last Post: aaron_one |
