Belt Area Squeal - PAS Pump?
£30 on ECP with discount anyway lol.
And, nope, mine gets louder with revs, it's bloody annoying at motorway speeds!
Is it leaking on the belt causing slip mone was!
As above, if the belt is tight and squealing isn't cured by revs then there's another issue. The tensioners can take up quite a lot of slack between them, could probably just about use a 1190 tbh.
(10-04-2014, 05:31 PM)pugmanxud Wrote: Is it leaking on the belt causing slip mone was!
Wasn't leaking, but replaced now anyway...squeal disappeared for a short while before coming back.
(10-04-2014, 06:38 PM)Poodle Wrote: As above, if the belt is tight and squealing isn't cured by revs then there's another issue. The tensioners can take up quite a lot of slack between them, could probably just about use a 1190 tbh.
Ah I didn't realise that, thought the belt tolerances were a little smaller tbh. Ordered one now anyway, 1183. Smile
  Cost of Timing Belt and Water Pump Replacement? JTaylor2005 7 5,692 12-02-2018, 03:29 PM
Last Post: JTaylor2005
  Best timing belt kit and water pump? JTaylor2005 13 7,561 23-09-2016, 10:11 AM
Last Post: BiG K
  Squeal when turning wheel DTubZz 5 3,027 24-04-2014, 07:31 AM
Last Post: DTubZz
