Wheel hub
Wanted: Wheel hub
In need of drivers side wheel hub must be 16mm, abs and close to Nottingham as possible.
if the 1.6 hubs are the same I have one altho not 100% on ball joint size.
Can you measure ball joint with vernier gauge? Needs to be abs too
Got a pair of 16mm hubs don't think they are abs ones thougj
i have some with abs will chuck them in with beam if u want them kent
(09-04-2014, 08:10 AM)kentiiboii Wrote: Can you measure ball joint with vernier gauge? Needs to be abs too
Most people might have a spanner closer to hand Smile
Just get an 18mm with the corresponding ball joint Wink
(09-04-2014, 12:13 PM)Andy! Wrote: Just get an 18mm with the corresponding ball joint Wink
I would but I have brand new ball joints on the car.
Ive sorted some from teddy.
I have a pair of 18mm .
bearings in working order if your desperate
(10-04-2014, 08:37 PM)reckord Wrote: I have a pair of 18mm .
I've sorted a 16mm one now thanks anyway.
