Wanted: Wheel hub - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Misc & Wanted (https://www.306oc.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Wanted: Wheel hub (/showthread.php?tid=23039) |
Wheel hub - kentiiboii - 08-04-2014 In need of drivers side wheel hub must be 16mm, abs and close to Nottingham as possible. RE: Wheel hub - ash23 - 09-04-2014 if the 1.6 hubs are the same I have one altho not 100% on ball joint size. Re: Wheel hub - kentiiboii - 09-04-2014 Can you measure ball joint with vernier gauge? Needs to be abs too Wheel hub - Sambarker - 09-04-2014 Got a pair of 16mm hubs don't think they are abs ones thougj RE: Wheel hub - Teddy - 09-04-2014 i have some with abs will chuck them in with beam if u want them kent RE: Wheel hub - tigerstyle - 09-04-2014 (09-04-2014, 08:10 AM)kentiiboii Wrote: Can you measure ball joint with vernier gauge? Needs to be abs too Most people might have a spanner closer to hand ![]() RE: Wheel hub - Andy! - 09-04-2014 Just get an 18mm with the corresponding ball joint ![]() Re: RE: Wheel hub - kentiiboii - 09-04-2014 (09-04-2014, 12:13 PM)Andy! Wrote: Just get an 18mm with the corresponding ball joint I would but I have brand new ball joints on the car. Ive sorted some from teddy. RE: Wheel hub - reckord - 10-04-2014 I have a pair of 18mm . bearings in working order if your desperate Re: RE: Wheel hub - kentiiboii - 10-04-2014 (10-04-2014, 08:37 PM)reckord Wrote: I have a pair of 18mm . I've sorted a 16mm one now thanks anyway. |
