File Line Function
/global.php 961 eval
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/showthread.php 1651 eval
Rockers '6 Is back
What did i tell you Tom . Why you no listen??
Im sure iv linked you to the guide in this thread. Its an epicly fun job , i hope you enjoy your self Tongue
Weird how its leaking water but not filling the car with steam :/
(25-10-2013, 12:28 PM)Tom Wrote: Weird how its leaking water but not filling the car with steam :/
Iv nevet had or heard of a leakey.matrix filling the car with steam lol
Steam comes from the leaking hot water? lol the air flow around the matrix would push all the steam out where ever the vents are pointing.
(25-10-2013, 01:23 PM)Tom Wrote: Steam comes from the leaking hot water? lol the air flow around the matrix would push all the steam out where ever the vents are pointing.
But that would then mean you have air in the system and the leaking matrix wouldnt be your biggest problem
Nah what happens with your kettle when it comes to boil? Steam. This is a similar situation. Had it in my old 106 although it wasn't that bad but it did fog up the windscreen so i couldn't see where i was going lol.
I also had this in my first phase1.
Had a steady drip on the floor. Then that was closely followed by lots of steam through vents etc windscreen was heavily condensated.
Just bypassed it back then and sold it
[Image: av5ym8.jpg]
(26-10-2013, 01:54 PM)Jimbo Wrote: I also had this in my first phase1.
Dodgy bugger Big Grin
[Image: siggy1.jpg]
Well the 6 is still alive just about but it's a little bit of state at the minute, parked up on the drive with the dash half out and no tax
Also have a new daily while she's off the road
[attachment=12651]
What is it?
I hope its a DT, but can't see any evidence of coal Sad
1.9 nad, woulda been nice to have a dt tho lol
Mmmm, bet that's pretty dire lol
Want a turbo?
Haha it would be nice Big Grin although its not bad around the lanes where you don't need top end
New matrix is in, now just have to get the dash and carpet back in
Have a decat On its way and will probably stick the omp mid pipe I've got in at the same time
Dash is back in and it's running, first time I've heard the engine in 2 months <3 been having withdrawal symptoms lol
Anyone fancy donating some part worn tyres and tax ? Wink
There was some cheap nankangs in the for sale section! Unfortunately you have to suck it up and pay the tax Sad
[attachment=14711]
It's good to be back.
BAAAWWPP!!
Bit of an update, she's now back on the road and seems to be going well need to bleed the rad through again as its got another airlock and need to get the carpets back in.
There's a few little niggles I need to work out like the blowers won't point at the windscreen anymore and the brake light switch is too close to the pedal so any slight bump sets it off but that's things that aren't urgent.
It's also on the old wheels as they're the only full set with decent tyres I have ATM
finally....Tongue
if you work out the blower issue, let me know, I have a 306 here that has the exact same issue.
Will do mate it's odd yas it directs the air correctly on the other settings and it doesn't jam on windscreen and isn't hard to select which makes me think it might not be the flaps or cable
Was wondering if there's a pipe not lined up right behind the dash
Something's out of kilter mate, maybe a pipe blocking the flap opening properly?
[Image: siggy1.jpg]
Doesn't feel like there's any resistance when you turn it though, I'd have thought if the flap was blocked it'd be very stiff to select or not possible at all
Has the cable got enough tension?
[Image: siggy1.jpg]
Not sure i hadn't thought of that, will check it when I get a bit of time
(31-03-2014, 10:00 AM)mr_fish Wrote: finally....Tongue
Think devils fuel is right with this mate, had a slight play earlier and can get the air onto the windscreen by playing with the end of the cable where it goes into the heater panel
Feels like when you put the dial on windscreen the cable bunches up at the heater panel if you push the loop out of the cable then air goes onto the screen but if you change the air to somewhere else and back you get the loop back in the cable
Glad you found the problem mate, fixing it is the next lol
Reppity rep??
[Image: siggy1.jpg]
Should have it now Smile
Cheers bigman Smile. Fixing my cable issue was a bitch as the clips to hold the outer cable were bust Sad
[Image: siggy1.jpg]
Cheers chaps, will check this out and let you know Big Grin
  Rockers '6 rocker8742 56 36,154 18-11-2017, 08:42 PM
Last Post: rocker8742
