Quick question
Quick question
Question
Question guys I'm Thinking about upgrading my brakes to the 4 pot brembos, do I need the reservoirs? And would the front old calipers fit on the back?
Moved to correct section.
I'm a noob
Are you thinking of the 406 brembos?
Front callipers won't fit the back. They won't have the handbrake mechanism either.
Not sure about the Brembo's though, I think people run the with the gti master cylinder but not sure.
Yes I am that's the ones
(17-03-2014, 05:21 PM)306Dan Wrote: Are you thinking of the 406 brembos?
Yes that's the ones mate
Will work fine with a 25mm Master cylinder from a gti/ newer HDi, just watch for wheel clearance as they are wiiiiide
(18-03-2014, 12:41 PM)HDi--Power Wrote: Will work fine with a 25mm Master cylinder from a gti/ newer HDi, just watch for wheel clearance as they are wiiiiide
I've got the 15s gti wheels hopefully they fit lol
Thanks again
They wont fit without spacers with those wheels Doh
I'm 99% sure brembos won't fit under cyclone wheels
10mm spacers and they will just about clear! Its not the circumference is the issue, its the width, they are huge!
Thanks again
I have them 10mm spacers? You think? Not a problem
Yes those wheels with 10mm spacers and they will fit! just
(18-03-2014, 01:24 PM)HDi--Power Wrote: Yes those wheels with 10mm spacers and they will fit! just
Just is good enough! Cheers guys
remeber to either buy some tarox discs or some earplugs too
(18-03-2014, 03:41 PM)306Dan Wrote: remeber to either buy some tarox discs or some earplugs too
Why is that mate? Lol
They squeal quite badly on standard discs
(18-03-2014, 04:10 PM)306Dan Wrote: They squeal quite badly on standard discs
I was thinking about drilled and vented discs anyways and better pads. But that's for the advice!
Do these need a custom mount or direct fit ?
Using Tapatalk
(27-03-2014, 09:34 AM)SupaStar88 Wrote: Do these need a custom mount or direct fit ?
Direct fit mate
Aw lovely Big Grin specially when the scrappy just told me 20 quid for then or 35 with the disk and pads in the boot [FACE WITH TEARS OF JOY] only thing, these fit behind my rims?
Using Tapatalk
  Quick question about Lemforder drop links titch 8 2,314 06-02-2014, 01:34 AM
Last Post: sweeney1987
