15-12-2011, 09:20 PM
XUD ragging - Jakes black DT 0-60 and 30-70......
28-02-2012, 09:28 PM
New videos required.
28-02-2012, 09:31 PM
Dan! Wrote:New videos required. Well you will have to wait.... my clutch is still bedding in!
On the 306 waiting list.
28-02-2012, 10:45 PM
4WayDiablo Wrote:lol nice jumpy needle on the 0-60 That's dans doing , hasn't stopped wobbling since he fiddled with it! ...
29-02-2012, 12:20 AM
Toxic-Jake Wrote:Lol dan breaking a 306? Makes a change :-P4WayDiablo Wrote:lol nice jumpy needle on the 0-60 ![]()
29-02-2012, 12:38 AM
looks pretty good.
29-02-2012, 04:26 PM
my gov modded pump doesnt let the engine rev anything like that
PH1 FTMFW!
29-02-2012, 06:29 PM
How much did you shim it Skoob? Got any photos? Could also be down to turbo or other fuel problems (crappy in tank strainer, clogged fuel filter (been running veg?) or a fuel leak between the hand primer bulb and the pump)
29-02-2012, 06:31 PM
I'm going to record mine. Low end spec 0-60 was 8.4 and a 30-70 at 7.6... Any good??
29-02-2012, 06:32 PM
Sounds pretty decent mate, get some vids up
29-02-2012, 06:38 PM
Dan! Wrote:How much did you shim it Skoob? Got any photos? Could also be down to turbo or other fuel problems (crappy in tank strainer, clogged fuel filter (been running veg?) or a fuel leak between the hand primer bulb and the pump) This much ![]() Don't have a vernier or ruler to measure the amount, but its off the top of an old glow plug. Seemed to fit lol. I still have the max throttle arm travel screw in place so I'll try it with that removed first. Turbo is a K14 with the actuator disabled. New fuel filter and I cleaned the pickup in the tank a few months ago, and I never let the fuel light come on.
PH1 FTMFW!
29-02-2012, 06:43 PM
I reckon the problem is your max throttle stop then, get that out and it will make the world of difference!
29-02-2012, 09:11 PM
got mine running at 29 psi now
![]() ![]() Team derv FLAME and CONROD spitters
01-03-2012, 11:28 PM
Removed max throttle screw, seems a bit more lively. Not much point going for more power till my clutch has been sorted though
PH1 FTMFW!
02-03-2012, 07:03 AM
Looking pretty quick for a light tune. :clap: What's the plans for it?
02-03-2012, 08:07 AM
Plans are going slow at the moment, I'm currently trying to sort out the paintwork for the show season, and once that's sorted I will be fmic & big boosting it
