XUD ragging - Jakes black DT 0-60 and 30-70...... - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: XUD ragging - Jakes black DT 0-60 and 30-70...... (/showthread.php?tid=428) |
XUD ragging - Jakes black DT 0-60 and 30-70...... - Dan! - 15-12-2011 ![]() ![]() Peaks at 24psi on a K14 with gov modded bosch. We made it just shy of 8 seconds for both, although it bound to be more like 11 seconds :? :roll: Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - Dave - 17-12-2011 That is about 8 seconds with the clutch kick into 2nd, good work dan <3 Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - declantg - 29-12-2011 She aint shy on power puts mine to shame i think
Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - Jake - 28-02-2012 Running more than 24psi now
Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - Dan! - 28-02-2012 New videos required. Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - Jake - 28-02-2012 Dan! Wrote:New videos required. Well you will have to wait.... my clutch is still bedding in! Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - 4WayDiablo - 28-02-2012 lol nice jumpy needle on the 0-60 Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - Jake - 28-02-2012 4WayDiablo Wrote:lol nice jumpy needle on the 0-60 That's dans doing , hasn't stopped wobbling since he fiddled with it! ... Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - 4WayDiablo - 29-02-2012 Toxic-Jake Wrote:Lol dan breaking a 306? Makes a change :-P4WayDiablo Wrote:lol nice jumpy needle on the 0-60 Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - Pompey306mark - 29-02-2012 looks pretty good. Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - SKoob - 29-02-2012 my gov modded pump doesnt let the engine rev anything like that needs moar washers i reckon
Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - Dan! - 29-02-2012 How much did you shim it Skoob? Got any photos? Could also be down to turbo or other fuel problems (crappy in tank strainer, clogged fuel filter (been running veg?) or a fuel leak between the hand primer bulb and the pump)
Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - ginge191 - 29-02-2012 I'm going to record mine. Low end spec 0-60 was 8.4 and a 30-70 at 7.6... Any good?? Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - Dan! - 29-02-2012 Sounds pretty decent mate, get some vids up
Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - SKoob - 29-02-2012 Dan! Wrote:How much did you shim it Skoob? Got any photos? Could also be down to turbo or other fuel problems (crappy in tank strainer, clogged fuel filter (been running veg?) or a fuel leak between the hand primer bulb and the pump) This much ![]() Don't have a vernier or ruler to measure the amount, but its off the top of an old glow plug. Seemed to fit lol. I still have the max throttle arm travel screw in place so I'll try it with that removed first. Turbo is a K14 with the actuator disabled. New fuel filter and I cleaned the pickup in the tank a few months ago, and I never let the fuel light come on. Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - Dan! - 29-02-2012 I reckon the problem is your max throttle stop then, get that out and it will make the world of difference! The amount you have shimmed yours is spot on tbh, plenty for a standard turbo anyway!
Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - David - 29-02-2012 got mine running at 29 psi now not taking it any more though :L
Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - SKoob - 01-03-2012 Removed max throttle screw, seems a bit more lively. Not much point going for more power till my clutch has been sorted though Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - Poodle - 02-03-2012 Looking pretty quick for a light tune. :clap: What's the plans for it? Re: XUD ragging - Jakes black DT 0-60 and 30-70...... - Jake - 02-03-2012 Plans are going slow at the moment, I'm currently trying to sort out the paintwork for the show season, and once that's sorted I will be fmic & big boosting it
