I've got some the 307 hdi 17" alloys (challengers) on my estate with 10mm spacers on the rear so the wheels are only on with the extra long bolts and have been told I will need spigot rings as when hit 70mhp cruising along the motorway it vibrates , so does anyone know what size I need?
What size spigot rings do I need?
22-03-2014, 11:21 AM
What size are you spacers etc? Spigot rings are used to change the size of the bore, like when you use after market wheels as the bore size is 73 (iirc) and peugeot is like 65.1 or something I can't remember.
Are the spacers taking away the lip of the hub so the wheel doesn't sit on it? If so it's hi centric spacers you want
22-03-2014, 03:16 PM
Yeah spacers have taken the wheel away from the hub
22-03-2014, 05:49 PM
As Matt said, if there's no lip on the spacers then they're not hubcentric, in which case spigot rings won't help. If there is a lip, which is smaller than the wheel, then you would need them. But that would only be the case if the centre bore of the wheels was wrong, or they're adapters, not just spacers.
22-03-2014, 06:16 PM
Ok cheers, looks like I need new spacers then
22-03-2014, 07:52 PM
Ill sale them cheap you mean, just need to find these new ones cheap
22-03-2014, 07:55 PM
Haha
get on eBay mate, I found a pair of two, with bolts for £35 before
23-03-2014, 09:15 AM
Got bolts though
| Spacers and spigot rings | Welshy_Pete | 2 | 2,538 |
08-07-2014, 04:38 PM Last Post: Sambarker |
| Alloy wheels, spacers, sprigot rings and bolts | mspdan | 2 | 2,518 |
06-01-2014, 01:56 PM Last Post: mspdan |
| Camber spacer rings ?? | Bender | 73 | 43,762 |
05-09-2013, 11:47 AM Last Post: Scott |
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg)
you can donate me your old ones
