Reverse Light Switch!
Wanted: Reverse Light Switch!
Smile
Hello,
Does anyone have a reverse light switch they could post today? The one on my replacement gearbox is different to the loom plug, and have rounded the nut trying to get the one from the other box!
It's the one with the small grey plug, x reg HDi if it makes a difference.
Cheers
Tom
Do you have the loom that was on the replacement box? if so, you can remove the plug housings and swap them over. The pins inside are the same. Just use two paperclips to free them although its a bit fiddly.
Hmm, other loom is still on the engine at Nans. I'm not good with fiddly things though haha.
Got a pic? Ive got my old engine and box but its from an 02 plate.
02 should have the newer style sensor, unless they changed it again.
Can get a pic in a bit, post has gone today anyway. I might just take apart the plug on my loom and clip the the wires on directly for now.
Drop me a pm if you do want me to check, i might forget to check back in this thread.
It's alright, I forgot to take the pic anyway lol.
Couldn't seem to separate the plug at all though! Confused
  Wanted: GTI6 Reverse Cable & Gearstick Eeyore 3 2,516 24-11-2014, 09:37 AM
  Wanted: Gti6 Reverse Cable Grant 9 4,643 08-04-2014, 10:27 AM
Last Post: welshpug
  Wanted: 6 speed reverse cable + lift up collar zx_volcane 7 4,112 24-11-2013, 03:26 PM
Last Post: HDIkyle
