Threads: 49
Car Model/Spec: HDI phase 3
As above what do I need to do?
Reason is 3 door seats are always on sale and usually cheaper as well. So before you say don't bother that's why
Got to love it when you have no idea
You 'just' need to swap the seat bases over from yours to the 3dr ones. But they aren't just screwed on unfortunately, needs to be cut off and welded on afaik.
Threads: 100
Just go to the scrap yard and get some nice 5 door seats.
Threads: 213
Car Model/Spec: HDI
Theres a guide on this on either this forum or theywhoshallnotbenamed.
I posted a question about this a few weeks ago on here.
Threads: 87
48
you can do it on some seats but it ends up with your seats an inch or two higher, didn't work on drivers side though as it was different so i had to retrim it . .
you will need a grinder . .
Threads: 49
(09-03-2014, 02:00 PM)Mattcheese31 Wrote: you can do it on some seats but it ends up with your seats an inch or two higher, didn't work on drivers side though as it was different so i had to retrim it . .
How easy to re trim
Threads: 87
48
(09-03-2014, 02:16 PM)camoturd Wrote: (09-03-2014, 02:00 PM)Mattcheese31 Wrote: you can do it on some seats but it ends up with your seats an inch or two higher, didn't work on drivers side though as it was different so i had to retrim it . .
How easy to re trim
big faf about mate, took me 2 days to sort it all out, i only did it because i got some blue fleck S16 seats, best seats ever put in a 306, seriously just keep your eye out for a 5 door set, much much easier . .
Threads: 371
29
Car Model/Spec: ford fiesta
http://www.theywhoshallnotbenamed/index....3doorseats found this link because I'm thinking about doing it o mine. From what I've heard the rear seats won't click into the upright position is this true? Mods to help fix?
Threads: 371
29
Anyone?
Threads: 87
48
They don't click in no, you'll just have to invent something mate.
Threads: 371
29
Fair enough won't be the first time I've gone macgyver
Threads: 371
29
Right incase anyone is still interested I started today by putting the rear seats from a 3 door to fit in my 5 door properly so they click in.
[attachment=14742]
So undo the rear covers on the zips
Also undo the two torx screws that hold the catch bit in place [attachment=14743]pull the seat cover forward. You can now put your hand inside and unclip the headrest bits. Two tags either side squeeze together and pull out from the top[attachment=14744]slide the.new seat cover in do the zips up and push the headrest bits back in. They will click back Into place.
You will be left with an odd shape hole that the 3 door cover has that 5 door doesn't you need to mod it like this
[attachment=14746] screw the cover back on. Now they fit and click in  [attachment=14747] and half way done. I'm going to do the fronts soon. Can put up how to swap the fronts soon when I do them if you need to.know.
Threads: 87
48
that's a good idea actually, i found a way to do it without involving the grinder lol, i think i might do this as i have some spare 5 door seats, would be a bit tidier . . . .
Threads: 49
(29-03-2014, 06:43 PM)Mattcheese31 Wrote: that's a good idea actually, i found a way to do it without involving the grinder lol, i think i might do this as i have some spare 5 door seats, would be a bit tidier . . . .
If u have found away please get it up on here so I can get it done as easier to find three door that 5 door
Threads: 371
29
I'm going to be doing it in the next few days not sure when yet. I'll take pictures and write it on here for others to see. I picked up the blue fleck ones in the pic for a tenner. So worth a try
Threads: 87
48
(29-03-2014, 07:58 PM)camoturd Wrote: (29-03-2014, 06:43 PM)Mattcheese31 Wrote: that's a good idea actually, i found a way to do it without involving the grinder lol, i think i might do this as i have some spare 5 door seats, would be a bit tidier . . . .
I've done it as I told you before, have a look in my project thread for more info if you're interested
Threads: 49
29-03-2014, 10:06 PM
(This post was last modified: 29-03-2014, 10:20 PM by camoturd.)
(29-03-2014, 09:23 PM)Mattcheese31 Wrote: (29-03-2014, 07:58 PM)camoturd Wrote: (29-03-2014, 06:43 PM)Mattcheese31 Wrote: that's a good idea actually, i found a way to do it without involving the grinder lol, i think i might do this as i have some spare 5 door seats, would be a bit tidier . . . .
Sorry mate completely misread lol will look now cheers mate
So did u just take the padding of the 3 door seats and put on your 5 door frames if so is it simple to do or take a good while?
Threads: 371
29
Fitted front seats today. They are a bugger I used this guide a little and made rest up. It's doable but took me around 3 hours with a bacon sarnie in between
Threads: 49
(30-03-2014, 03:49 PM)tombarnard1989 Wrote: Fitted front seats today. They are a bugger I used this guide a little and made rest up. It's doable but took me around 3 hours with a bacon sarnie in between
Yeah am hoping for a way without a grinder as I don't have one to use
Threads: 371
29
30-03-2014, 07:42 PM
(This post was last modified: 30-03-2014, 07:42 PM by bashbarnard.)
Where are you you're welcome to BORROW MINE
CAP LOCKS not intended stupid tablet
Threads: 49
Portsmouth mate guessing far from you lol
Threads: 371
29
Yeah a touch I'm Suffolk way
Threads: 49
Lol anyway I heard doing it the guide way the driver seat is a little high
Threads: 371
29
A touch but not excessive it was a pain to do drivers one tbf
Threads: 49
Ah fair enough so passengers was easy then
Threads: 371
29
So easy I'm going to remove the up down adjuster today on drivers to make it sit a little lower but involves making a very simple bracket. When I make it I'll take measurements and put on here. That way really easy to get the right height seat.
Threads: 87
48
yeah i followed that guide BUT . . . . . .if you're fitting S16 seats like i was the drivers seat is different and the guide doesn't work, that's why i ended up re-trimming the drivers seat, swapped subframes on the passenger though and i wouldn't want to be sitting that high up myself, adds another inch or so . . .
Threads: 49
(31-03-2014, 11:13 AM)Mattcheese31 Wrote: (30-03-2014, 03:49 PM)tombarnard1989 Wrote: Fitted front seats today. They are a bugger I used this guide a little and made rest up. It's doable but took me around 3 hours with a bacon sarnie in between
Fair enough I will just retrim both side lol
