Threads: 13
2
Car Model/Spec: Whats a 306?
24-02-2014, 06:03 PM
(This post was last modified: 24-02-2014, 06:04 PM by Wor Jimmy.)
(24-02-2014, 12:38 PM)martyn92 Wrote: Cant wait to see this finished, didnt think it was going to happen when I read the first 2 pages or so. Its one of my favourite threads now
Yeah things did go off on a tangent abit like.
(24-02-2014, 04:13 PM)7057sam Wrote: This looks so epic
Great job so far
Cheers
...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
Threads: 13
2
I have no f*cking clue.... but it looks good.
Engine Cradle - Wishbone Support
![[Image: 1620743_10151915366482274_793877902_n.jpg]](https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash3/t1/1620743_10151915366482274_793877902_n.jpg)
Were it tapers off at the back.. The very end of the tube is were the back of seats will be. and the swing arm of the end..like this
Threads: 465
114
Car Model/Spec: Vauxhall
i dont see how your going to keep this under 400kg
the engine gearbox and running gear alone has got to be near 300kg without your steal tube chassis
Threads: 13
2
(24-02-2014, 08:31 PM)cully Wrote: i dont see how your going to keep this under 400kg
needs to be 450kg or under
Engine is 180kg tops?
Frame up to now is only 21kg and there is only a little more cradle to go around the engine and seats
Drive shafts / hubs I'v yet to measure. the uprights (hub carrys) will be swapped out for aluminum uprights if needs be. 1/5th weight of the cast iron uprights.
Seats will be folded aluminum sheet, padded of course. Or fiberglass whatever is cost effective at the time.. Max 10-15kg with rails.
Nuts and bolts and various mounts 20kg MAX
Wheels. 10kg each. (Not sure if thats with or without tyres) Back one will be slightly more.
So say 280kg up to now? That leaves 120kg for Drive shafts/tyres? and an extra 50kg for being totally off with my calculations and it end up being a 2 tonne monster.
Threads: 169
91
Given 1 thank(s) in 1 post(s)
I wouldn't be so sure.
A bare Gti engine weighs ~125kg. Add a ~40kg box to that, then all the auxiliaries, and in your case a turbo etc you've gotta be looking at the wrong side of ~200kg.
But then arguably you won't have power steering?
Or air con
Threads: 13
2
(24-02-2014, 10:12 PM)Grant Wrote: I wouldn't be so sure.
Or air con
Power steering maybe be coming off as it may be over kill...
Of course i will have air con.. Directly in to my face.. *click lid visor open*
Threads: 4
Nice to see the chassis coming along
Dunno if these figures are any use.. I found my weighbridge slip recently and my MK is 640kg with about half a tank of fuel (10l). My chassis weighs approx 75kg. My gbox is a bit heavier than a 306 and I've got the diff/sierra drive shafts at the back which are quite weighty, and an extra wheel, my cobra seats are heavier than fibreglass ones but they're not too bad. 450kg will be a challenge. Nothing wrong with a challenge though
Threads: 13
2
24-02-2014, 11:01 PM
(This post was last modified: 24-02-2014, 11:02 PM by Wor Jimmy.)
(24-02-2014, 10:43 PM)Xud Missile Wrote: Nice to see the chassis coming along
Your rear diff is 200kg alone.. honest haha
Were do you find weighbridges? at the scrappys?
Threads: 4
Haha, yeah local metal yard let me use their bridge for a fiver
Threads: 226
24
Car Model/Spec: A3 TDi
Lol i just take some scrap with me and i end up getting paid to use the weigh bridge haha
Threads: 13
2
Recap of what i need to do / buy before I get a test ride.
Buy --
Some kind of seat.
Steering wheel.
Brakes/lines.
Foot pedals.
wheels/tyres.
Wishbone bushings.
Front and Rear shocks.
Things to do.
Make / attach wishbones.
make up rear swing arm.
Mount engine
Mount steering
Mount your mother
Mount Wheels
Mount a seat
I'm probs missing a lot here.....
Threads: 35
3
May has missed it, but wheres the battery going ? im guessing you can use a smallerish one? Lights?
CONVOI EXCEPTIONNEL
Threads: 13
2
25-02-2014, 10:26 PM
(This post was last modified: 25-02-2014, 10:27 PM by Wor Jimmy.)
(25-02-2014, 10:15 PM)martyn92 Wrote: May has missed it, but wheres the battery going ? im guessing you can use a smallerish one? Lights?
This is just a list for the test. Batt will be a normal one at first. under the passenger seat or something to counteract a much as i can of me sitting on the right.
Lights will be going on waaaay after the test.. if it works.
Threads: 36
2
Car Model/Spec: PH2 Dturbo
There's a public weighbridge in seghill James. And I'll be breaking my 306 up when i find a replacement.
Threads: 55
17
Car Model/Spec: 406 V6
27-02-2014, 07:06 PM
(This post was last modified: 27-02-2014, 07:19 PM by Rippthrough.)
That geometery looks like it's going to have terrible bump steer. That's also a fair bit of scrub, you might want to keep the power steering...
Threads: 13
2
(27-02-2014, 07:06 PM)Rippthrough Wrote: That geometery looks like it's going to have terrible bump steer. That's also a fair bit of scrub, you might want to keep the power steering...
Like I said.. I have no f*cking clue
Tbh any help would be appreciated
Threads: 55
17
For what you're doing, you'd be better off keeping the struts and standard front geometry.
Threads: 169
91
What did you use to get the diagram of the Geometry?
Coming along nicely
Threads: 13
2
(28-02-2014, 09:29 AM)Rippthrough Wrote: For what you're doing, you'd be better off keeping the struts and standard front geometry.
Struts as in the springs? ... if i kept them i would have even more trouble trying to mouth the top ends :\
Threads: 55
17
No, as in the whole strut/upright assembly, just keep the stock geometery since you're using standard shafts and rack...
Threads: 13
2
01-03-2014, 01:03 AM
(This post was last modified: 01-03-2014, 01:04 AM by Wor Jimmy.)
(28-02-2014, 09:46 PM)Rippthrough Wrote: No, as in the whole strut/upright assembly, just keep the stock geometery since you're using standard shafts and rack...
True, I was thinking of getting a sub frame + wishbones from a 306.. and fabbing up an upper control arm, nothing major is welded in place yet, so it can change if needed. (Just waiting on dean so i can take his car to bits  )
Threads: 591
54
Fyi: xud engines weigh a fair bit less than 125kg and surely a gearbox isnt 40kg?!
Crack on bud
Threads: 13
2
(01-03-2014, 07:34 AM)Piggy Wrote: Fyi: xud engines weigh a fair bit less than 125kg and surely a gearbox isnt 40kg?!
Crack on bud
Its all contradicting!! I'm going for that it weighs on the heavy side, that will make sure i don't go over weight in the end
Threads: 226
24
Can the vehicle weigh 450 on its own? Im guess it wouldnt be illegal if it was over 450 with you in it... Just asking because people are heavy lol.
Threads: 13
2
(01-03-2014, 11:11 AM)Tom Wrote: Can the vehicle weigh 450 on its own? Im guess it wouldnt be illegal if it was over 450 with you in it... Just asking because people are heavy lol.
It could be up to 1000kg - But then only the old type car license could ride it
My motorbike licence only lets me ride a trike thats up to 450kg in weight
450kg unladen so no passengers, but needs half tank of fuel, oil ect.
Threads: 226
24
Yeah that makes sense, question answered cheers
Threads: 13
2
(01-03-2014, 11:33 AM)Tom Wrote: Yeah that makes sense, question answered cheers
No probs bud. Off in to the garage.
Threads: 13
2
Some more pictures for you, Making sure the frame will fit.
The swing arm is there for a test. a new one will be made to fit a wider section wheel.
Threads: 169
91
(01-03-2014, 07:34 AM)Piggy Wrote: ...and surely a gearbox isnt 40kg?!
Have you ever changed a clutch?!
Threads: 13
2
(01-03-2014, 06:15 PM)Grant Wrote: (01-03-2014, 07:34 AM)Piggy Wrote: ...and surely a gearbox isnt 40kg?!
Dean did his back in last time we did a clutch lol
