T25 turbo
T25 turbo
Anyone on.here running a T25 turbo on there d turb what are they like for fitting and all that
Jenks and padge have, they're slow spoolers, get a td04 or better IMO..
Ah really scrap.that then.haha td04 is cheaper too
I have a hybrid T25. Spools up almost as quick as my GT15, has loads of grunt and good top end. Not as much as a td04 I'm sure but instant boost. I doubt headbutting 6k constantly is good for an old engine. Jenks put mine on, main problem was the oil line, get a flexi and save loads of time! However, now it's on I love it. However, it is a hybrid and different to a standard T25. I'd go for a GT20 if I was putting another turbo on.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Hmm I've seen a t2/T25 hybrid.forsale got me interested but wanted 250
The td04 is a whole heap better than the T25... And personally my td04 was faultless all the time, never really bothered me how it drove.
How laggy is your td04?
When I had td04 on I didn't think it was very laggy tbh, found it quite nice to drive, but fitting gt20 to my 205 as moving with the times not sure if I'm gonna like it or not but bought a bigger turbo ready to replace it if I don't like it.
Gt20 always sounds good in the write ups but the td04 has been.done so many times and it's cheap and people make adapters on here
Personally i never found it laggy because i never needed to cram my foot into the carpet, you just feed it in and its no trouble at all. Not like its slow either, with the right pump and in the 205 i was lighting up 3rd gear for fun.
Yeah 205 I bet with no weight would be fun I had a totally standard 1.9 gti loved till its spit the gearbox haha
Only thing you have to bash the bulk head with tdo4
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
(27-02-2014, 05:11 PM)karl1989 Wrote: Only thing you have to bash the bulk head with tdo4
Depends which manifold you put it on Smile
Not true!
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Yeah thats bullshit, i put pine on a k14 mani and it was fine.
not once had to smash a bulhead, on either T25 or td04, TD04 is a much better turbo, my T25 didn't even start to boost until 2800-3k, td04 started at around 2400-2500 and was a much more aggressive pull.
Aggressive pull.that sounds nice Smile
bang for buck you cant go wrong with a td04, its just 90% of big turbo xuds now run td04s, gets a bit boring now.
And with a td04 most cars snap rods, it's like fitting a time bomb Wink
I've not once chucked a rod, just lucky I guess! Wink
oh and ive also ran a t2/t25 hybrid, this was much better than a t25, spooled like a t2 and went like a t25, was one of the best turbos ive ever ran.
Yeh I've been in a t2/t25 hybrid, they are pretty spool happy.
Some peeps do need to move on from the 90s and its turbos...
Its 2014 and a small GTB turbo would completely embarrass a T25
yeh, but when a T25 and T2 are both peanuts, I managed to make a bolt on fitting t2/t25 hybrind for less than ten quid, it was real bargain basement tuning but added lots of hp for buck. If your a real scoundrel and dont care if compressor wheels go down your intake if they're not balanced then do this, otherwise I wouldn't recommend though :p
(27-02-2014, 12:42 PM)sherman306 Wrote: Hmm I've seen a t2/T25 hybrid.forsale got me interested but wanted 250
Knock him down a bit a get it.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
For 250 quid you could buy and fit a very nice 2056/big KKK turbo.... With a proper downpipe....
These T2/T25 hybrids are they just a T25 in a T2 turbine housing? Or is there a difference between the professionally built ones and the ones thrown together?
Mine was professionally built with a cutback turbine wheel to relieve backpressure as well as a full 360* thrust bearing, staggered oil seals, balanced and blueprinted. According to jammapic.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Anyone can do bearing and oil seals, its the machining thats awesome! Just wondered how the homebuilt ones were put together.
Think its badically a t2 exhaust side reemed out so a t25 slots in.
