fan blows only on setting 4?
as above, does anyone know the cause/solution to this problem?
Well it may or may not help you, but I had a similar thing with my old work van...basically the blower decided to stop working in the widdle of minter, and the workshop said it was some kind of resistor that had given up, and so "fixed" it by bypassing it, so I could use the blower heater, but it would only work on max.
As said, probably not really of any actual help, but a cool story nonetheless. Wink lol
Try the resistor pack pal, it's in the motor itself iirc, but they're easy to get to, if not look at the switch or the circuit relay
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
thankyou for the replys, its something I shall look into over the weekend and try and sort out,
