fan blows only on setting 4? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: fan blows only on setting 4? (/showthread.php?tid=21560) |
fan blows only on setting 4? - LeeRallye - 21-02-2014 as above, does anyone know the cause/solution to this problem? RE: fan blows only on setting 4? - WiNgNuTz - 21-02-2014 Well it may or may not help you, but I had a similar thing with my old work van...basically the blower decided to stop working in the widdle of minter, and the workshop said it was some kind of resistor that had given up, and so "fixed" it by bypassing it, so I could use the blower heater, but it would only work on max. As said, probably not really of any actual help, but a cool story nonetheless. RE: fan blows only on setting 4? - ADV_93 - 21-02-2014 Try the resistor pack pal, it's in the motor itself iirc, but they're easy to get to, if not look at the switch or the circuit relay RE: fan blows only on setting 4? - LeeRallye - 22-02-2014 thankyou for the replys, its something I shall look into over the weekend and try and sort out, |
