oil leak at vacuum pump end
got a very slight oil leak on vacuum end off the head swaped the seal still leaking the odd drip is there a seal on camshaft on that end ? cheers
Have you got a pic of the pump? if they are the same design as the GTi ones, i always found keeping a new seal on there and running a bead of sealant around the outer edge of the pump where it meets the face of the head works.
same as that pal
[Image: index_zps94272f0d.jpg]
That'll be your 'o' ring then.
Tried a new one or some intant gasket?
Theres two o rings I had to fit a vacuum pump to the xantia engine when I fitted it, just used 2 new seals and seemed to be fine.
cheers lads will have a look
Pain in the arse ive had a few new seals on it and some gasket sealant and it still leaks.
Ive given up to be honest.
  Major fuel pump problems, air leak, head gasket? Dantheman1312 2 4,308 22-08-2016, 09:57 AM
Last Post: r3k1355
  diesel pump leak callumh121 3 2,761 08-04-2016, 11:10 AM
Last Post: callumh121
  Presumed Lucas Pump Leak ozpug 4 3,657 10-09-2015, 12:28 PM
Last Post: pioneer DJ paddy
