Threads: 13
Car Model/Spec: Whats a 306?
[attachment=13394]
To be honest.. these are about the same size as a gearbox off a 1000cc motorbike.
If i can mock up some sort of selector drum this might just work.. even by using the original gearing.
...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
Threads: 226
24
Car Model/Spec: A3 TDi
07-02-2014, 09:57 PM
(This post was last modified: 07-02-2014, 10:17 PM by Tom.)
If you can make our gear boxes sequential some how, you will sell a massive amount of the bits to convert them. Sequential is so racecar and we all love that!!
Just watched this... http://www.youtube.com/watch?v=E1APhLQVtlE
So basically weld a few pins onto the selector forks and machine a drum then gogogogo???
Threads: 13
07-02-2014, 10:20 PM
(This post was last modified: 07-02-2014, 10:27 PM by Wor Jimmy.)
Say I did set one up for a XUD, using the same bell housing/cases. would it fit any other models? Say a 6 or something.
(07-02-2014, 09:57 PM)Tom Wrote: If you can make our gear boxes sequential some how, you will sell a massive amount of the bits to convert them. Sequential is so racecar and we all love that!!
Just watched this... HHHHHHHEEEEEYYYYYYYY A VVVIIIDEOOOOOO
Ha seen that a weeks or so a go.
like i said it just needs a selector drum. The ballache is keeping reverse gear.!!
With the space in the cases, the reverse gear may have to go bibi.. or relocated to a random place
Threads: 226
24
07-02-2014, 10:34 PM
(This post was last modified: 07-02-2014, 10:35 PM by Tom.)
Have reverse on a cable and a boot popper solenoid...
Remember the '6 has a 6 speed box as opposed to our measly 5 speeds
Threads: 7
Car Model/Spec: 106 slo-nad
Given 7 thank(s) in 7 post(s)
Get an electric motor for reverse, on your non driven rear wheel. simple.
Get crackin on a sequential box now!
Threads: 34
8
Given 8 thank(s) in 8 post(s)
(07-02-2014, 10:45 PM)Martin306 Wrote: Get an electric motor for reverse, on your non driven rear wheel. simple.
This.
That's how it was on our Westfield, an electric motor in between propshaft and the fire blade gearbox, came off though as it's just a track weapon
Threads: 13
07-02-2014, 10:51 PM
(This post was last modified: 07-02-2014, 10:52 PM by Wor Jimmy.)
I was thinking more along the lines of selling to other people after its tested lol  so i wish to keep the rev in the gearbox itself
Or at least the plans on how to do it. Guide ect..ect
Tom.. Are they the same on the outside though? like same bolt holes, to bolt on to the crank?
Threads: 226
24
Yeah '6 box fits xud engine.
Threads: 13
(07-02-2014, 11:09 PM)Tom Wrote: Yeah '6 box fits xud engine.
Good to know cheers bud.
I'm going to carry on with the trike build and do the seggy on the fly..
on a side note.. anyone got some f*cked gearboxes?  (just incase)
Threads: 151
14
Car Model/Spec: 306 D-turbo
ive got a few more
Team Doesn't own a 306
Threads: 13
07-02-2014, 11:20 PM
(This post was last modified: 07-02-2014, 11:23 PM by Wor Jimmy.)
By f*cked I mean free
Oh.. just add one of these! there only...... $19,000???? might fit a 306
http://sheptrans.com/products/evo-x-5-sp...-gear-box/
Threads: 55
17
Car Model/Spec: 406 V6
08-02-2014, 12:05 AM
(This post was last modified: 08-02-2014, 12:12 AM by Rippthrough.)
(07-02-2014, 09:57 PM)Tom Wrote: So basically weld a few pins onto the selector forks and machine a drum then gogogogo???
And remove the synchro's, and rings, have a full dog-engagement gearset and selector rings machined. And mod the casings for bearings for the selector shaft, if you can even fit it in.
May as well just buy a dog box by the time you've done.
Threads: 13
(08-02-2014, 12:05 AM)Rippthrough Wrote: (07-02-2014, 09:57 PM)Tom Wrote: So basically weld a few pins onto the selector forks and machine a drum then gogogogo???
Calm down.. its a bit of fun
I'm trying to do this cos I'm a lazy. not for SUUPER DOOPER fast gear changes at 12k rpm  oh wait its a car engine.  I mean 1.2k rpm
syc-mesh will do.. hopefully...
Threads: 55
17
Well, if you ain't changing the gears, why even bother mucking about inside the box trying to use a selector drum?
Use the forks that are already and just run a converter on the outside of the box to change it from H-pattern to sequential.
You'll probably f*ck the synchro's anyway from the force/speed you try to change with a lever setup like that, but at least it's ten times easier to make and if the box dies you just bolt it on the next one...
Threads: 13
(08-02-2014, 12:43 AM)Rippthrough Wrote: Well, if you ain't changing the gears, why even bother mucking about inside the box trying to use a selector drum?
Its just a bit of fun to be had with a spare box.. there is one already on the engine.
How much are those converter things again?
Threads: 55
17
Make one...
Threads: 13
08-02-2014, 12:58 AM
(This post was last modified: 08-02-2014, 01:09 AM by Wor Jimmy.)
(08-02-2014, 12:51 AM)Rippthrough Wrote: Make one...
Back in half an hour.. have to look shit up now  Damn you..
Nope.... Sticking to my guns. Happy times.
(If i blow a box.. No worries Danny2009 has a few) :ROFL:
Threads: 55
17
08-02-2014, 01:08 AM
(This post was last modified: 08-02-2014, 01:09 AM by Rippthrough.)
Just a selector drum, ratchet and two cables.
You can even do it with just a pair of doubled up ratchets pulling on the cables, although harder to setup as you need them on springs then.
Threads: 36
Car Model/Spec: PH2 Dturbo
Think we need to make the frame up, and get the engine running before thinking about a seggy box at the moment, as you want this built tested and on the road for pugfest in 5 months... uhhhhh lol
Threads: 151
14
5 month! better get welder out then!
Threads: 13
(08-02-2014, 11:25 AM)Dean Wrote: Think we need to make the frame up, and get the engine running before thinking about a seggy box at the moment, as you want this built tested and on the road for pugfest in 5 months... uhhhhh lol
Fheck! ... Come over then! .. noob
Threads: 13
Laying out the frame,
Its going to be 1.6m at the widest point (tip of wheels)
Length is going to be about 2.3m From Front of wheels to back of back wheel..
but the front of the frame will protrude past the wheels.. by 300mm ish.
Threads: 226
24
But the big question is can you just left off quick and bang it into the next gear without using the clutch? Or do you NEED the dog something synchros to do that? This would strictly be sequential and you would still need to use the clutch as you do now?
Threads: 13
08-02-2014, 05:21 PM
(This post was last modified: 08-02-2014, 05:23 PM by Wor Jimmy.)
(08-02-2014, 03:30 PM)Tom Wrote: But the big question is can you just left off quick and bang it into the next gear without using the clutch? Or do you NEED the dog something synchros to do that? This would strictly be sequential and you would still need to use the clutch as you do now?
Need the dog gears for that, synchro gears have to.. sync up before the gear change is smooth. Dogs you can just bang it in.. in fact the faster you change the smoother it is
I was on a great website last night. i will try n find it...
Found it! http://www.carbibles.com/transmission_bible.html its 2/3rd the way down i think
Threads: 36
James when have you booked holidays in for work? As in after April ish.
Threads: 13
(08-02-2014, 06:17 PM)Dean Wrote: James when have you booked holidays in for work? As in after April ish.
Nah I've got like 30 odd days to use lol. what days you wanting to go? Gimme the days you wanna go.. i can sharp book em off.
Threads: 169
91
Interesting read this
Make me a sequential box
:p
Threads: 13
08-02-2014, 07:08 PM
(This post was last modified: 08-02-2014, 07:18 PM by Wor Jimmy.)
(08-02-2014, 07:02 PM)Grant Wrote: Interesting read this
:p
Seggy will be coming after the build sorry  .
I'm going to make one for me.. test it for a month.
How i do it, Still unknown
What about a kit to bolt on to the gearbox in some way to convert?
Dont ask.
[attachment=13419]
Threads: 36
and after you've tried yours for a month, i want one
Threads: 13
(08-02-2014, 07:59 PM)Dean Wrote: and after you've tried yours for a month, i want one
Nope.
