27-01-2014, 11:05 PM
(27-01-2014, 10:57 PM)Mitch Wrote: I think stock torque is 145 ft/lbs could be wrong though..
Sweet jesus..
![Confused Confused](https://www.306oc.co.uk/forum/images/smilies/confused.png)
...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
XUD TDT- Status = SELLING ALL THE BITS.
(27-01-2014, 10:57 PM)Mitch Wrote: I think stock torque is 145 ft/lbs could be wrong though.. Sweet jesus.. ![]() ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
27-01-2014, 11:10 PM
(27-01-2014, 11:05 PM)TallGuySmallBike Wrote:(27-01-2014, 10:57 PM)Mitch Wrote: I think stock torque is 145 ft/lbs could be wrong though.. Just had a quick look on parkers, they say 197nm, which is 145 ft/lbs ![]()
Blaze '6 and Blaze D-turbo!
27-01-2014, 11:21 PM
(27-01-2014, 11:10 PM)Mitch Wrote:(27-01-2014, 11:05 PM)TallGuySmallBike Wrote:(27-01-2014, 10:57 PM)Mitch Wrote: I think stock torque is 145 ft/lbs could be wrong though.. i'm going to strip a 306 gearbox. measure some internals. compare it for shaft dia. compare teeth on gears for overall strength comapred to a 1.2l motorbike one. time will tell ![]() ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
28-01-2014, 09:33 AM
It may well not be the torque that destroys it as such, but how low down that torque is.. bike engines rev to like 13k, you'll be getting max torque at like 2.2krpm in a 1.9 XUD
28-01-2014, 09:36 AM
the FJ is quite torquey down low for a bike. And like James said, they use the FJ1200 motors for drag bikes with 30+ PSI boost.
28-01-2014, 09:43 AM
Aren't you going to need some crazy long final drive to even make use of a bike gearbox?
28-01-2014, 08:02 PM
(28-01-2014, 09:43 AM)Midnightclub Wrote: Aren't you going to need some crazy long final drive to even make use of a bike gearbox? I'm not sure yet. thats why i wish to take a look see ![]() If its to much of a ball bust i will just not bother lol ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
28-01-2014, 08:15 PM
If it is a ball buster, then just man the f*ck up and learn to shift with a car shifter
28-01-2014, 08:25 PM
(28-01-2014, 08:15 PM)Dean Wrote: If it is a ball buster, then just man the f*ck up and learn to shift with a car shifter Its not the case of "manning the f*ck up" .... Its the case of i am a lazy rider... or in this case. driver. ![]() ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
28-01-2014, 08:41 PM
thats true, have you got a pump and injectors sorted?
(28-01-2014, 08:41 PM)Dean Wrote: thats true, have you got a pump and injectors sorted? heck no. ![]() Doing the frame/wheels ect first. PAINT! Kaboom!... Yeah.. downloading inventor again now ![]() [attachment=13162] I have no f*cking idea what i am doing... ![]() ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
29-01-2014, 10:26 PM
Parts coming SUNDAY!
29-01-2014, 11:54 PM
(28-01-2014, 08:58 PM)TallGuySmallBike Wrote:(28-01-2014, 08:41 PM)Dean Wrote: thats true, have you got a pump and injectors sorted? That's really good for paint
30-01-2014, 10:08 PM
Can i ask what you're doing for a handbrake?.. or just gonna leave it in gear
30-01-2014, 10:32 PM
Why do you need a handbrake, even a a 306 doesn't have one
(30-01-2014, 10:08 PM)Dean Wrote: Can i ask what you're doing for a handbrake?.. or just gonna leave it in gear Needs it to pass the check test. Back wheel will have a disk, one large caliper for the actual braking. Smaller one off flea bay (cable operated) and have a lever somewhere in the cab I Could be fancy as f*ck and use a hydraulic set up for it lol. (motorbike caliper + master) ![]() 1. Hazards are a retro-fit must for all trikes. 2. Handbrake - A trike must have a seperate mechanical handbrake which must operate as follows:- If the trike is under 450kg and therefore a Class 3 MOT, then the handbrake must operate on at least ONE wheel of the axle. If the trike is over 450kg and therefore a Class 4 MOT, then the handbrake must operate on BOTH wheels of the axle. (the assumption being that a mechanical emergency/parking/handbrake operates on the rear axle) 3. Headlights For all trikes over 50cc and capable of more than 45mph Trikes over 1300mm wide must have 2 headlamps at the front. Unless they are motorcycle derived - in which case they only need 2 headlamps if over 1700mm wide. The tester's interperatation of "motorcycle derived" is:- that if a trike has a car engine/gearbox/rearaxle and car like controls such as hand gearcghange then it is car derived (no matter where the front steering originates) then the 1300mm rule applies. ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
30-01-2014, 11:07 PM
(This post was last modified: 30-01-2014, 11:35 PM by Rippthrough.)
(28-01-2014, 09:33 AM)Midnightclub Wrote: It may well not be the torque that destroys it as such, but how low down that torque is.. bike engines rev to like 13k, you'll be getting max torque at like 2.2krpm in a 1.9 XUD It'll be the shock loadings, and the torque pulses from a diesel (lets face it, they ain't up there on the list of smooth powerplants) Shock is what kills gearboxes and shafts more than anything, that's why the gears we use in the buggy are over an inch wide even though they're made from decent stuff. That's also why the drag bikes tend to strip the gearkit out and fit 3 really damned big gears instead of the stock 6.
30-01-2014, 11:59 PM
(30-01-2014, 10:32 PM)TallGuySmallBike Wrote:(30-01-2014, 10:08 PM)Dean Wrote: Can i ask what you're doing for a handbrake?.. or just gonna leave it in gear Rear calipers off the gti,s have cable operated handbrake, sure the 106's + 206's are the same. Tbh most are probs like that now. Headlights aren't a problem really, can get some like off your old FJ and just mount some switches to some Perspex. And if it has a car engine + gearbox with car controls does It still count as a trike? Or is there a set of guidelines for that. (30-01-2014, 11:59 PM)Dean Wrote:(30-01-2014, 10:32 PM)TallGuySmallBike Wrote:(30-01-2014, 10:08 PM)Dean Wrote: Can i ask what you're doing for a handbrake?.. or just gonna leave it in gear I never said they would be a problem ![]() ![]() it wont need to be mega power on the brake since its under 450kg. its a different class of trike. but i can still drive it (yet people with car licences cant) hahahaha (30-01-2014, 11:07 PM)Rippthrough Wrote:(28-01-2014, 09:33 AM)Midnightclub Wrote: It may well not be the torque that destroys it as such, but how low down that torque is.. bike engines rev to like 13k, you'll be getting max torque at like 2.2krpm in a 1.9 XUD Got any pics on the buggy/gearbox? ect? Lets face it. the way i am thinking of doing probs wont work. but I'm still keeping a spare gear box (a normal one that will probs go on first) and just tinkering on with trying to make a seggy ![]() ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
31-01-2014, 02:52 PM
Beastly....
![]() 1.25" bore/shaft ? ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
31-01-2014, 06:06 PM
(This post was last modified: 31-01-2014, 06:10 PM by Rippthrough.)
It varies from ~32 to 40mm depending on the gear position. It undercuts down to 25mm at 5th gear so we can't use 5th at all
31-01-2014, 07:32 PM
(31-01-2014, 06:06 PM)Rippthrough Wrote: It varies from ~32 to 40mm depending on the gear position. It undercuts down to 25mm at 5th gear so we can't use 5th at all 5th's for cruising Ed doesn't do that!
Perv 306 1.6 5 Door Hore - Sold 110bhp 207 Hdi Sport - Used as a Brake 173bhp T25 Ph1 Diablo Dturbo - Scrapped Thirsty Bitch Volvo 850 Estate - Sold 51bhp Berlingo Nad DT Van - Sold Slow as f*ck Dispatch Work Horse www.prestige-auto-care.co.uk
31-01-2014, 07:59 PM
I'm still ripping apart some gear boxes. fun to be had.
![]() Also need to get my hands on a tube notcher. ..I'v got a lend of a hydraulic pipe bender (capable of 2" ish.. ) Anyone selling/loaning? ![]() ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
31-01-2014, 08:07 PM
Tube notcher, i have no idea what one of them are, and whos is the pipe bender?
Did you manage to get autocad sorted out?
31-01-2014, 08:41 PM
(31-01-2014, 08:07 PM)Dean Wrote: Tube notcher, i have no idea what one of them are, and whos is the pipe bender? Puts a inverted radiut type cut on the end on a pipe at straight/ fancy angles Mute it.. annoying voice lol . I could make one.. but would have to stick more time into it and i just cba. ![]() as for Inventor... Getting there ![]() ![]() Pipe bender is martins ![]() ![]() ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
31-01-2014, 09:18 PM
(31-01-2014, 08:07 PM)Dean Wrote: Tube notcher, i have no idea what one of them are, Man with an angle grinder.
31-01-2014, 09:41 PM
(31-01-2014, 09:18 PM)Rippthrough Wrote:(31-01-2014, 08:07 PM)Dean Wrote: Tube notcher, i have no idea what one of them are, God no ![]() ![]() ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
31-01-2014, 09:44 PM
Pretty sure JTF sell an automatic hoist for £74.
31-01-2014, 10:01 PM
(31-01-2014, 09:44 PM)Dean Wrote: Pretty sure JTF sell an automatic hoist for £74. 74 quid? fheck off. rather lift it with my nut sack. http://www.ebay.co.uk/itm/Wolf-1-Ton-1-T...41748d9bb5 ...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
