Threads: 169
91
(16-01-2014, 01:18 PM)Matt Wrote: f*cking love that wink mirror!
Runs to eBay!
It's epic. It eliminates the blind spots completely. Makes driving so easy now haha
Threads: 28
Getting there with the Welding dude. Need to slow down..gonna put me outa work
Threads: 169
91
![lol lol](https://www.306oc.co.uk/forum/images/smilies/legacy/lol.gif) Haha, it's by no means pretty. Looks like Stevie Wonder was let loose. Holds though
Threads: 28
Good boy ![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png) that's what I did with mine. After the first lot which I wedged in fell out :p
Threads: 448
51
They are awesome! Ones I've seen are quite pricey though!
Threads: 169
91
16-01-2014, 02:09 PM
(This post was last modified: 16-01-2014, 02:09 PM by Grant.)
Thirty quid posted I think this one cost
And that was from the 'States
Threads: 448
51
Nice! Same ones I've seen
What thickness steel did you use for your switch panel btw? Need something similar for switches in the dturd lol
Threads: 169
91
I used a bit of 2mm sheet ally I 'found' at work. May have one kicking about if you want
Threads: 448
51
Yes please if you do ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png) will sort me out a treat!
Threads: 169
91
No worries. When you gonna come get it
Threads: 169
91
Threads: 448
51
Ill get it from ace next month?
Subframe looks sweet! Can't wait till you have it on, see how much difference there is
Strut brace looks like its going... Urm... Well?
Threads: 169
91
Haha cheers mate. All will be revealed
Threads: 448
51
I'm very interested haha. This car gets more interesting with every update
Threads: 169
91
So just spent 70 quid on; tubular steel, nuts, bolts, aero catches and grip tape
Sounds like one f*cked up bondage party!
Threads: 169
91
Clearly you are too much of an amateur then! :p
Threads: 171
46
Looks awesome mate! Love the work :-)
Threads: 169
91
(22-01-2014, 06:55 PM)4WayDiablo Wrote: Looks awesome mate! Love the work :-)
Cheers Phil
So cracked on tonight with the upper brace. Can anybody guess what's going on yet?
Mounts all dry fitted:
Bars all welded together. Ish.
Gotta now remove my battery box, and re-route my fuel hoses to fit this. happy days
Threads: 51
Car Model/Spec: Did Have Track Prepared GTi 6
Looking handy with the welder mate!!
Threads: 28
Nice work mate
Love to see lots of custom fab...
My fave bit of working on my car!
Threads: 169
91
24-01-2014, 09:30 AM
(This post was last modified: 24-01-2014, 09:31 AM by Grant.)
Cheers for the comments guys
It definately is the best part of working in your car. Just bolting stuff on can Only get you so much satisfaction. Building something from scratch and then it all working fine, that's sense if acheivement there.
That said, I've still gotta finish it ![lmao lmao](https://www.306oc.co.uk/forum/images/smilies/legacy/lmao.gif) might not fit :p
Threads: 169
91
Well, its in!
All fits, snug as a bug. Just gotta paint it now.
Threads: 18
10
You sure that the engine won't touch that as rocks/moves slightly coming on and off the power? Might be plenty of clearance there and it's just the photo that makes it look tight, but worth keeping in mind as engines do move a surprising amount on standard mounts.
Threads: 169
91
(24-01-2014, 12:27 PM)powerandtorque Wrote: You sure that the engine won't touch that as rocks/moves slightly coming on and off the power? Might be plenty of clearance there and it's just the photo that makes it look tight, but worth keeping in mind as engines do move a surprising amount on standard mounts.
I'm pretty confident it will be fine
I have welded in 5mm steel on either side of the engine mount so there it very little movement at the top of the engine there. There is about 10mm between the engine and the brace. I think the angle of the photo isn't the best.
Threads: 169
91
Boom!
Threads: 27
20
S16 engine ɑnd box grant! 70
81
That looks awesome painted up!
Threads: 226
24
Car Model/Spec: A3 TDi
Thats f*cking cool! Iirc Grants got a solid lower engine mount so i cant see the engine moving that much.
