Threads: 213
Car Model/Spec: HDI
Has anyone done this before and have any tips?
I know that sand paper, primer, spray paint and clear coat is needed but just wanting to know how other people would/have done it?
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Take your time with every stage, don't rush anything. Prep work is key, as is a warm, clean, dust free environment to paint in.
I always get impatient at the last minute and ruin it :p
Threads: 142
58
Car Model/Spec: E46 BMW 320d
(16-01-2014, 11:10 AM)zx_volcane Wrote: Take your time with every stage, don't rush anything. Prep work is key, as is a warm, clean, dust free environment to paint in.
Exactly this really.
I did mine in my mums shed in the end, hung up on a piece of string from one of the bolts. As said though, I kinda rushed the lacquer stage, and one end of the spoiler only ended up with a VERY light coat that didn't really cover properly.
Threads: 169
91
Don't do it when it's raining outside (if you are painting in a garage or shed etc) and make sure you are in a warm environment
Threads: 213
Car Model/Spec: HDI
16-01-2014, 11:26 AM
(This post was last modified: 16-01-2014, 11:35 AM by MY95.)
Thanks, yes would be done in a barn or shed etc, you sound like you have done it quite a few times before?
(16-01-2014, 11:20 AM)Grant Wrote: Don't do it when it's raining outside (if you are painting in a garage or shed etc) and make sure you are in a warm environment
thanks, wouldn't be doing it outside in the rain anyway haha
(16-01-2014, 11:14 AM)WiNgNuTz Wrote: (16-01-2014, 11:10 AM)zx_volcane Wrote: Take your time with every stage, don't rush anything. Prep work is key, as is a warm, clean, dust free environment to paint in.
thanks for sharing your experience, so what items did you buy to paint yours?
What kind of black spray paint would go best with my silver 306?
Threads: 142
58
I bought the standard issue primer, paint and lacquer, already had wet n dry paper in a range of grades, but I would recommend a good seeing to with 1200 grit between coats, ESPECIALLY after each coat of primer, to help reduce the orange peel effect when you're finished.
Threads: 213
Car Model/Spec: HDI
(16-01-2014, 12:22 PM)WiNgNuTz Wrote: I bought the standard issue primer, paint and lacquer, already had wet n dry paper in a range of grades, but I would recommend a good seeing to with 1200 grit between coats, ESPECIALLY after each coat of primer, to help reduce the orange peel effect when you're finished.
What do you mean by standard issue items, as in Peugeot official primer, paint etc? Thanks!
Threads: 169
91
I was more talking about the humidity in the atmosphere. It will affect the paint
Threads: 213
Car Model/Spec: HDI
(16-01-2014, 12:31 PM)Grant Wrote: I was more talking about the humidity in the atmosphere. It will affect the paint
Thanks mate
Threads: 142
58
(16-01-2014, 12:27 PM)MY95 Wrote: What do you mean by standard issue items, as in Peugeot official primer, paint etc? Thanks!
Nah, halfrauds own mate, the Diablo paint I bought from there was actually a pretty close match, but sometimes it can be miles out!
Threads: 169
91
16-01-2014, 03:02 PM
(This post was last modified: 16-01-2014, 03:02 PM by Grant.)
(16-01-2014, 02:53 PM)WiNgNuTz Wrote: (16-01-2014, 12:27 PM)MY95 Wrote: What do you mean by standard issue items, as in Peugeot official primer, paint etc? Thanks!
It depends on what age your car is as Peugeot, being Peugeot, used a gazillion different shades for some colours.
Threads: 142
58
Yeah I know, and it all depends what shade halfords have in when you decide to buy some!
Threads: 169
91
Yeah exactly that!
Threads: 142
58
Basically, I got lucky when I bought the paint for my spoiler and sideskirts!
Threads: 183
20
Given 8 thank(s) in 8 post(s)
Use plastic primer. It sticks much better. :-) as said before take your time, Clean the surface, warm the cans up. Prep work is the key. Give it plenty of time to stiffen up before fitting because I had tape marks on mine. But sanded them out and and polished it up.
