P bush Partner to 306
Guide: P bush Partner to 306
Rainbow
I found this out so thought I'd post this on here the size needed with the thread length also.
The M10 x 1.25 bolt with 16mm thread length I found out today. It is the original small bolt used on the peugeot parnter P bush.
I wasn't sure on the length needed but found out. So anybody else needing 2 you can get it on the link below.
link to bolts needed
http://www.ebay.co.uk/itm/321069728170?s...1423.l2649
link to P bush
http://www.ebay.co.uk/itm/330439783888?s...1497.l2649
Those bolts you've linked to are A2 grade stainless - you really don't want to be using those on suspension parts IMO.
You want a high tensile bolt grade 8.8 or higher.
