Guide: P bush Partner to 306 - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Guides (https://www.306oc.co.uk/forum/forumdisplay.php?fid=9) +--- Thread: Guide: P bush Partner to 306 (/showthread.php?tid=20425) |
P bush Partner to 306 - Welshy_Pete - 14-01-2014 I found this out so thought I'd post this on here the size needed with the thread length also. The M10 x 1.25 bolt with 16mm thread length I found out today. It is the original small bolt used on the peugeot parnter P bush. I wasn't sure on the length needed but found out. So anybody else needing 2 you can get it on the link below. link to bolts needed http://www.ebay.co.uk/itm/321069728170?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 link to P bush http://www.ebay.co.uk/itm/330439783888?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 RE: P bush Partner to 306 - powerandtorque - 14-01-2014 Those bolts you've linked to are A2 grade stainless - you really don't want to be using those on suspension parts IMO. You want a high tensile bolt grade 8.8 or higher. |
