mercades c250 gt20
mercades c250 gt20
Another one from this corner of the earth. We really need to sort a Bicester meet when I'm back from holiday.
I'm around too Smile
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
ah lots of local people, a meet would be good
ive got a scooby Td04 on at the moment, but i think i got lucky when i guessimated the angle, and welded the exhaust.
ill have a look at rickys thread.
306 XUD9 gt2052s
306 hdi stage 2 (hdi tuning)
205 STDT -new project
Something like this www.ebay.co.uk/itm/321233914589
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Good link there...handy that...
some turbos have the V band flange on them already so das is goot
So can you weld that v band thing to the turbo? Looks good idea saves the messing of trying to get it at the right angles
i think the v band on the gt20 is slightly bigger than 3 inch (not a common size), from mercades the correct clamp for that turbo is around £15 quid, so i could buy that and then make a custom band to weld to my three inch elbow.
306 XUD9 gt2052s
I used a 3" elbow with v band clamp, had to grind down the mating surface on the turbo for the clamp to fit though. I also used a TD04 actuator aswell. I had mine on a dyno but made poor results because it was very de tuned because I didn't want to blow it up, I've seen how quickly the EGT's rise on boost.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
heres i few pictures
sorry for hi-jacking your thread by the way
yeah i thought i might have to square off the turbo face.
so you used a 3 inch v band clamp?
306 XUD9 gt2052s
That's identical to how mine was.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Ive just acquired one of these Merc C250td turbos and it is confusing the hell out of me lol
The id plate says the following;
GT20
A6050960599
454 156 - 1 AL0001
A/R Turbine side is .38
A/R Compressor side is .51
You would think it has to be a GT20 of some variation but the dieselavante site gives it as a GT25c based on the A6050960599 nr so it is contradicting itself.
If it is a GT20 has anyone a clue as to what derivative of GT20 it is?
It was said some were that gt25c is bascily a gt20 just the old code for it.
Few measurements taken from the turbo i have;
Comp Exducer - 52mm
Comp Inducer - 40mm
Turbine Exducer - 52mm
Turbine Exducer - 40mm
Rough measurements, only had a tape measure, my uncle nicked my calipers.
Does that sound like a GT2052s, or at least a version of one?
Yep...
I have this turbo on my C250TD
GT20
A6050960599
454 156 - 1 AL0001
I'm trying to find a rebuild kit for it as the bearings have way too much play in them.
Anyone know where I can get a kit from ?
I did order one from ebay but the seller supplied a GT15-25 universal kit (which just doesn't fit) and now can't supply the right kit.
I even sent him the full part number before ordering.
Contact Garrett and see if they provide a service kit for it?
I've bought a kit of these before-
Melett Limited
Unit N Zenith Park
Whaley Road
Barnsley
S75 1HT
United Kingdom
Main Sales Line +44 (0)1226 320939
Wasnt your turbo but i am sure they could sort one out Smile
  gt20 exhaust system Chris_90 13 7,024 15-10-2014, 07:42 AM
Last Post: Mike
  Gt20 sherman306 32 18,123 14-03-2014, 05:23 PM
Last Post: Chris_90
  TD04 to GT20 oil feed anto 11 7,330 07-03-2014, 11:46 AM
Last Post: anto
