gti 6 cutting out
Hi all hope someone can help me here I have a gti 6 and sometimes when I. Coming to a stop while breaking the car will cut out it has also done it a few times when I have gone round a few corners tbe car will fire straight back up it has had new idle controle valve fitted a few months ago many thanks wibbz
idle control valve
common fault I believe
but the going round bends is odd....enough fuel?? is there an intank strainer on the '6?
He has said he has replaced the ICV....
Was it an OE quality part? Do you know what make?
Are you in an engaged gear when this happens?
did you clean out the plastic port on the manifold when you changed the ICV?
Made sure all pipes are connected properly to icv and the bolts are tight. The I ring in place on it properly? I know I snagged mine once and it would seem like I had a faulty icv
Thanks for your responses guys it was a icv from a local motor factors I will double check all bolts and pipes again as for the fuel I never have it below quarter of a tank
Reset the ecu
Can work wonders!
^^ and that, did you reset the ecu after fitting the new parts?
After I fitted an icv, with out resetting, it would idle at 2k or stall haha
It could be the ICV again if its just a cheapo one. Alot of people have had problems with cheap ones only last a very short time.
