Threads: 90
Yeh nothing to worry about, leaks are only bad when you cant build pressure with an airline as its flowing out as fast as it comes in.
Threads: 25
Car Model/Spec: Dturbo
Cheers Darren.
I couldnt work out what to use to plug the pipes and used a screw drivers handle end, imagine my surprise when i created a bloody air powered screwdriver harpoon!
I eventually welded up a little capping pipe....much better/ safer
Threads: 90
Haha yeah, i normally use motorbike pistons, can normally find one right size, but in this case used what was to hand!
Worth noting if possible its a good idea to do it pre turbo to test that two, as ive seen compressor housings weeping a tonne of air before around the cartridge!
Threads: 25
I might give that a try, just a matter of fitting an intake pipe and capping it.
Threads: 19
Bit of a resurrection but the noise is immense.
what happened with this then?
Threads: 90
Lol didnt know you filmed me on way home Mark lol.
That was after FCS on the route back to Cornwall!
Ive just been daily driving the thing for the last few months...nothing particually amazing going on with it really, couple youtube updates if you check the channel
Threads: 163
53
Car Model/Spec: 406 HDI
(14-08-2013, 11:23 AM)mr_fish Wrote: Bit of a resurrection but the noise is immense.
That sounds pornographic!
Threads: 6
Must be time for an update.
Threads: 90
Bit of an update seen as though my forum input has been rather dyer recently.
The Audi has been going ok, but have been quite busy with other things etc, so has been some what neglected /daily driven etc. But still been tuning it harder and harder over time, but sadly reached the limit of the stock clutch, well we reached the torque limit some time ago, but have been getting around it by using rpms, but after the last stint of tuning (dropping the pipe reading to weld up 4inch straight pipe) it has resulted in a hike in power / torque across the rev range, which has resulted in the clutch getting raped, and now simply impossible to drive unless you turn the power down.
I cant remember what i last posted, but the car is basically now running a 12mm 6 cylinder VE, with homemade injectors with larger nozzles / removed the pilot injection, so basically running big old school singer poppers, which sound like a tractor, but make good clean power. Turbo is a third gen GTB2260VK, and various other bits and bobs here and there, but other than the mtdi convertion and turbo, engine is largely stock.
Random video which kinda captures the clutch problems , problem is alot worse now, but gives you the idea.
http://youtu.be/lRi_mGRiGYc
Ive been having a problem with an oil leak on the turbo oil return, due to the stupid vag solid steel design, so made the decision to fix that as MOT is coming up, and quite frankly fed up with topping the oil up, its just been put off time and time again due to the farce involved in stripping it. So started stripping that, but in the end came to the conclusion I didnt like the vag design, and want to just weld the hole in the block shut, and run my own return to the sump, coupled with the fact the clutch wasnt mann enough, and an exhaust gasket was blowing, I decided to pull the engine out:
Front end stripped (this process is now almost faster than stripping a 306, amazing how you get used to farcing with cars)
Yanking the sucker out with Chris:
On the floor, tis a big old lump:
And where she once came from:
As you can see, engine really is in a state, mainly simply down the the fact its just been a budget lol build from day 1, and pretty much 0 pounds of budget has gone into parts unless they effect performance.
So plans really while engine is out is to clean it up, change some gaskets that are weeping, repair a few issues, fab up the oil return, change the clutch, looking at getting a paddle made up, as cant see a stock clutch being hugely better even if new. Biggest problem ive got is now the motors on the floor, the ongoing airflow problem is right in your face / just asking to be sorted with bigger manifolds / collectors / then do the heads while its apart. But must resist this, as this car is not for spending money on!! Just want to tidy it up / bring back the super reliability, as with it leaking oil / raping the clutch, its become a problem really to use....
Threads: 36
Car Model/Spec: PH2 Dturbo
can't beat the noise of a 6 banger, well unless its a 8 banger etc.
But even still mech controlled tdi lump is such an achievement.
You got this on the Audi forums? would like to see the reaction to the VE pump.
Threads: 90
Nah dont use any vag forums, cant stand vag tbh, only working on this as its uncles / for fun really. cant squeeze a 6 banger into the 306 and cant afford to drop a x30D motor in a 505
Threads: 36
Best get something done with the 306 then
Threads: 71
Car Model/Spec: 205 dt
(24-11-2013, 08:40 PM)darrenjlobb Wrote: ..... the ongoing airflow problem is right in your face / just asking to be sorted with bigger manifolds / collectors / then do the heads while its apart. .....
Met a pretty interesting guy the other day that fabricates all sorts, usually land rover and 4x4, but anything really. had a morris minor with a 2l fiat twin cam in he'd just made all the exhaust manifolds up on looked really good job if you want me to put you in contact? in st day before orchards.
Car Model/Spec: 306 D Turbo
Bloody hell, she makes a noise! Is this really your uncles, or just an excuse to keep diesel in your veins?! lol
How smooth do those injectors run on idle, bet shes quite lumpy...
Threads: 102
9
(24-11-2013, 08:40 PM)darrenjlobb Wrote: Bit of an update seen as though my forum input has been rather dyer recently.
Darren you want to try working on a jeep cherokee liberty crd, half of the engine is in the bulk head practically! a proper bitch to get access to sensors!
I have just replaced the crank senor, a proper bitch putting the car back together.
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
What power doe these put out standard and any estimation of what its at now?
That's an AFB engine - so 150hp... Last time I went in it it was a good 220-230+ but from the sounds of things, the power has been hiked somewhat.
Threads: 90
Was hoping to throw it on the dyno up roche this week, but the clutch said no, hence tore the motor out but will get a paddle in it, and let her rip and see what she will do!
Threads: 541
124
Epic build dude. Would be amazing if it was a Quattro.
Threads: 163
53
Still love the mentality. Oh the ECU is f*cked? Sod it, rip it out and bolt a VE on it!
Threads: 90
Yeah typically quattro boxs and rear ends have been appearing my watch list quite a few times just recently.
Threads: 266
18
What figure are you hoping for Darren?
Threads: 90
Meh not really "hoping" for anything.
The motor has a huge ammount more potential than what i am really releasing due to so many restriction, mainly within intake / exhaust, but not going to through money at it much more.
It will be what it is...given the weight of the car, and how well it goes, it must be fairly up there id imagine.
Threads: 266
18
Fair enough, you must have a rough idea of what your "expecting" then rather then "hoping" for!
I'll guess at around 240 bhp / 450 lbft.
The torque levels are insane off that motor, she's not what you might call "revvy"
1800rpm - oops, lit the front axle up in 4th...
Threads: 90
Looks out drivetrain, this time you will be feeling the torque!
Just a typical CG paddle like i used on the DT / alot use on here. Only specced it with springs this time to try and retain the oem+
Threads: 541
124
(25-11-2013, 04:44 PM)Ruan Wrote: The torque levels are insane off that motor, she's not what you might call "revvy"
You make me want one of these sooo much.
Threads: 374
38
Car Model/Spec: GTI 6
So i take it you have a second crane to manoeuvre the gearbox back on? that transmission is HUGE.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Beastly man clutch
Sprung ftw, got them in mine and its still not great stop start through busy cities, dread to think what unsprung is like.
