Turbo to manifold bolts
Just about to refit my turbo, its held on to the manifold by 3 M8 studs, How can i make sure they don't come loose? was going thinking about locktight but will it take the heat or is them coming loose not a real problem on diesels? i could also lock two nuts on
Its not a problem usually do them up tight and they be fine
[Image: av5ym8.jpg]
just wound them up tight then put 2nd nuts on them, hope they will be fine as its really hard to access them on a 307
Go get some new nuts from pug? They look to be special locking ones.
[Image: sig.jpg]
You can get locking nuts that use a metal insert instead of the nylon so they dont melt, I used copper lock nuts on my manifold and they never came loose.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
  Hdi manifold/turbo? help! Strikeforce 8 3,807 05-06-2014, 05:15 PM
Last Post: Poodle
