Precatalyst removal
Getting this thing off was a real pain, can i cut it out and weld a pipe in or will it cause it to fail the mot?
[Image: 6810d1376897800-peugeot-307-sw-136-what-...-image.jpg]
Should be Hdi section...
umm give us a clue what car it is?
Its a 307 hdi, this is in the incorrect section. this thing in between the Turbo and DPF filtter, service box says it a Precatalyst do i really need it or can i make it smaller/easier to fit?
is this the one with the pressure sensors befor and after as iff you remove it it will flag up a pollution fault i think it needs mapping out too
Is that not the Dpf? this has got a sensor before and there is a second sensor in the Dpf, you could be correct but i thought the one in the Dpf was a EGT sensor?
http://www.citroenet.org.uk/passenger-ca...tech3.html
